RV.Net Open Roads Forum: Fifth-Wheels: Switching tow vehicles
 > Switching tow vehicles
Jkmrich
CA
Posted: 05/29/19 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone. Quick question for those in the know. I’ve seen the light and just purchased a new Ford Super Duty replacing my 1/2 ton tow vehicle. I have a Pull-rite 3100. The new truck came with a 5th wheel prep package. Can I just swap the pull-rite into the Ford then take it to be inspected or is it more in depth? Thanks!
BB_TX
McKinney, Texas
Posted: 05/29/19 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Not familiar with the 3100. But the Ford factory prep is a “puck” type system meaning the hitch must have the pins that drop thru and lock into the bed of the truck. Your hitch must have those pins, and the proper spacing to fit the Ford. Or you must buy an adapter.
schlep1967
Harrisburg, PA
Posted: 05/29/19 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Call Pull-Rite customer service. Tell them your hitch model/serial number and the exact truck you bought and they will tell you exactly what you need.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Jkmrich
CA
Posted: 05/29/19 10:14am Link  |  Quote  |  Print  |  Notify Moderator
I called pullrite, that hitch is designed only for a 1/2 ton. Time for an Anderson!
allen8106
Burrton. KS
Posted: 05/29/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Demco sells an adapter plate for newer trucks with older hitches
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 51
MFL
Midwest
Posted: 05/29/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Andersen does not make a hitch to fit your puck system. You need to sell your Pullrite hitch, and purchase a B&W 3300, that will be a perfect fit to your pucks. You have a great NEW TRUCK, get the best hitch for it, that is designed to drop right in.
Jerry
Jkmrich
CA
Posted: 05/29/19 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the suggestion. I however do not want a stationary hitch.
IdaD
Idaho
Posted: 05/29/19 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
If I had the factory pucks I'd probably get an adapter and then drop the rail mount Andersen on top of that. I think the Andersen style works better than a traditional hitch, it's a great value and it's super easy to install and remove.
2015 Cummins Ram 4wd CC/SB
grizz272
frozen tundra, WI
Posted: 05/30/19 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2018 F350. The Andersen ultimate hitch fits the Factory Ford puck system nicely.
Jkmrich
CA
Posted: 05/30/19 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
I called Andersen yesterday and they said no rack is needed as well.
