RV.Net Open Roads Forum: Could it be simply a matter of more air in the tires?
Search only in Tow Vehicles
 > Could it be simply a matter of more air in the tires?
Atlee
Mechanicsville, VA
Posted: 05/30/19 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Last Thursday, I replaced the OEM BF Goodrich Rugged Trail LT245/75R17 LRE tires with the identical sized BF Goodrich All Terrain KO2 tire.
Up until last Thursday, my truck with the OEM tires (always inflated to 55# front/60# rear per the yellow sticker on the door jam) and the Jay Flight 23RB trailer were an extremely stable combo. 99.9% of all passing 18 wheelers never wiggled the combo. Normal winds had little effect.
However, the first tow with the new tires and same trailer, loaded about the same, was closer to a white knuckle affair. The air pressure in the new tires was the same as the OEM tires, 55# front/60# rear.
Would it help if the new tires were aired up more? Say to 65 or 70 in the rears, and 5 to 10 pounds more in the front?
The basic tread design is exactly the same between the two tires. However, the new tires are 3 pounds heavier per tire, has a slightly deeper tread, and counting the heavier, larger shoulder lugs, is about .5 inches wider.
Any thoughts?
Erroll, Mary, Duffy the Dachshund (RIP)
2018 Jayco Redhawk 22J
2017 Jayco Jay Flight 23RB
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
And Blue Ox WDH/Sway Control
dmck413
Fluvanna Va
Posted: 05/30/19 05:39am Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem going from Michelin to Firestone on the rear of my truck.They got better on the return trip from M.B with no pressure change. I think they had to break in a little.
Tvov
CT
Posted: 05/30/19 05:45am Link  |  Quote  |  Print  |  Notify Moderator
I would give it a try, just don't go over the max pressure on the tires themselves.
Also try inflating front and rear the same, see how that works. You have a good hitch setup, probably transferring a lot of weight to the front of the truck.
2008 F-250 CrewCab 5.4L,
dodge guy
Bartlett IL
Posted: 05/30/19 05:48am Link  |  Quote  |  Print  |  Notify Moderator
Yes, they need to go through some heat cycles. Give them a thousand miles. I would also up the pressure as you recommended. I don’t like running “E” rated tires below 60 psi.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Tvov
CT
Speaking of hitches and weight distribution - try adjusting the hitch for a little more (or less) weight distribution. With my camper, I like to tow with a heavier tongue, feels better.
Also, have you changed anything in the camper? Moved things around? Any extra weight anywhere? Try moving stuff around to change the weight distribution inside the camper.
MFL
Midwest
Posted: 05/30/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
My experience with new tires is a break-in period makes a big difference. They do seem to squirm more, even when not towing, but airing them higher has helped, until adding some miles. It takes some miles, more being better, but by 5K, it is what it is.
Jerry
carringb
Corvallis, OR
Posted: 05/30/19 06:14am Link  |  Quote  |  Print  |  Notify Moderator
^What they said. The first 500 miles (A/T tires especially) are noticeably squirmy. Some brands worse than others but it might just be an affect of how "green' the tires are.
Since the new tires are wider, you actually might see better handling with slightly less pressure, as wider tires carry more load for the same PSI. Running the same PSI can keep the tire shoulders from making good contact.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
IdaD
Idaho
Posted: 05/30/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
KO2s are squirmy at first. Put some miles on them and it'll go away.
2015 Cummins Ram 4wd CC/SB
Turtle n Peeps
California
Posted: 05/30/19 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Read all about your problems HERE.
Replacing tires on a TV right before a vacation trip is akin to buying new hiking boots right before a big hiking trip. "Some" tires, like boots take a while to break in.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Posted: 05/30/19 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Squirmy new tires, it'll go away.
FWIW, they are not the same basic tread design, not even close.
Rugged Trails (cute name, considering they are one of the harder compound, non snow, non AT, non mud tires out there) are pure pavement pounder tires. Great wear, no noise, smooth.
BFG AT's are almost the exact opposite. Just about as aggressive of an AT tire as you can buy before it's considered a mud tire. Excellent traction in all conditions. Not loud, but louder than highway tires. Softer compound, wear quicker.
Great tires, just different than your previous tires.
