RV.Net Open Roads Forum: Tow Vehicles: 2015 GMC Sierra Denali-catastrophic fuel pump failure
Search only in Tow Vehicles
 > 2015 GMC Sierra Denali-catastrophic fuel pump failure
Page of 8
Halmfamily
Munford, AL
Posted: 05/30/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
This is why I won't give up my '08 GMC Duramax as it has the CP3 pump.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
p220sigman
Tallahassee, FL, USA
Posted: 05/30/19 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I would definitely try to get to the corporate level for a goodwill warranty. My BIL had the same thing happen with his and was able to get them to cover it. He had to go through a few layers of people before he got someone with the authority to approve it and who would.
Good luck with it. If you can't get them to cover it, I'd at least check with your insurance to see if there is anything they can do.
Skidus1
Utah
Posted: 05/30/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
The new ones use a different pump is that correct? My 07.5 has only 47k on it but I will be needing a bigger truck in the next couple years and don’t want to worry about this when I upgrade.
FishOnOne
The Great State of Texas
Posted: 05/30/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
2019 6.7 Cummins/CP4 Ram.... Your next!
OP,
Good luck with GM covering that bill.
* This post was edited 05/30/19 08:14pm by FishOnOne *
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
FishOnOne
Posted: 05/30/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
That is correct. They now use a Denso brand pump for better or worse.
Lantley
Ellicott City, Maryland
Posted: 05/30/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
I know this is a known issue but the consumer should not be on the hook for this.
Maybe I'm in a fantasy land but a 2015 truck should not need a $12K repair.
If there was no negligence or vandalism involved
The consumer needs more protection than that. The trucks are too expensive to not be built to withstand the current fuel standards. There is a major flaw in the entire system!
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
rhagfo
Portland, OR
Posted: 05/30/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
See if this can be installed at the same time.
CP4.2 bypass kit
rhagfo
Portland, OR
Posted: 05/30/19 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
reelcamper1 wrote:
No extended warranty, not covered on drivetrain! Thanks for all the info....still trying to get them to pay for costs! Going to try the suggestion for "goodwill warranty" money as suggested
Interesting that the fuel system is not covered under drivetrain warranty?
ACZL
UPstate,NY
Posted: 05/31/19 02:18am Link  |  Quote  |  Print  |  Notify Moderator
FWIW, my '16 Freightliner Cascadia for work with a DDT 13 engine recently had 2 injectors go south thus causing the engine to shut down. Dealer quoted $10,000.00 to replace all 6 injectors (made by BOSCH who also recommends replacing all 6) @ $750.00 each! If this isn't bad enough, extra diesel was pushed thru the system, so DEF filters need replacement as well @ $3,000.00. So yes, the GM dealer probly isn't too far out of line.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
SpeakEasy
Western New York
Posted: 05/31/19 03:09am Link  |  Quote  |  Print  |  Notify Moderator
Not to hijack the thread, but...
I was going to buy a Ford extended warranty until I read that any part that failed as a result of a failure of a covered part was NOT COVERED. I suppose that sort of thing is standard fare in the warranty world. I declined the purchase.
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
Page of 8
