RV.Net Open Roads Forum: Tech Issues: Magnum error code
 > Magnum error code
was_butnotnow
Fulltime: Emery, SD
Posted: 05/31/19 12:08am Link  |  Quote  |  Print  |  Notify Moderator
Getting high volts AC
Any ideas what is causing this.
Now in a 05 Monaco Cayman DP 36 PDQ
Traveled many years in NuWa Hitchhiker 5th wheels.
Travel Journals and Adventures of people living this lifestyle Hitchitch.com
Personal blog with our own travels. www.fulltime.hitchitch.com
cavie
Posted: 05/31/19 01:09am Link  |  Quote  |  Print  |  Notify Moderator
Assuming your looking at the incoming AC power voltage I suggest you use a volt meter and go outside and plug test the voltage at your shore power and see what it reads. They should be the same.
KD4UPL
Swoope, VA
Posted: 05/31/19 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Just the inverter providing power or are you plugged in? Plugged into shore or generator? 30A shore connection or 50A connection?
dkreuzen
Lake Havasu City, AZ
Posted: 05/31/19 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Look in your owners guide:
"High Volts AC appears on the LCD.
The FAULT (red) LED is on. The
PWR (green), CHG (green), and INV
(green) LEDs are off.
High Volts AC – This fault causes the charger to be disabled because a
very high AC voltage (>150 VAC) has been detected on the AC input.
Remedy: Remove all AC power from the inverter’s AC input for
at least 15 minutes to automatically restart this fault. Ensure only
120VAC power is connected to each of the inverter’s AC inputs."
Dennis
2012 Monaco Knight 36PFT
2019 Jeep Grand Cherokee Overland
2005 Jeep Wrangler Unlimited Rubicon on 2007 16' Car Trailer
CA Traveler
The Western States
Posted: 05/31/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
I had 160V once and my HW50C prevented the smoke from escaping.
2014 Grand Cherokee Overland
Bob
pianotuna
Regina, SK, Canada
Posted: 05/31/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I'm glad to know that high voltage is not allowed to pass through. Just one more reason for me to NOT have a surge device, but rather to rely on the autoformer.
Does the manual list the number where it cuts off the voltage?
Regards, Don
 > Magnum error code
