RV.Net Open Roads Forum: tested the blue camco filter with a TDS meter
 > tested the blue camco filter with a TDS meter
Page of 6
TechWriter
On The Road
Posted: 08/16/20 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
For potable water I plan on installing an RO with PH balancing stage. The PH adds calcium and Mg back into the water - since RO strips out everything.
Excellent idea. I just started using this "remineralizer".
way2roll wrote:
I plan on installing the RO in a bin rather than under the sink and run the lines for supply. I have not pinned down what I will do with the wastewater. The units I buy are 1:5 waste water to filtered. Normally in a house the wastewater goes down the drain. In an RV I may capture it and recycle it or just let it drip on the ground. Happy to hear from anyone who's handled this.
I suggest under-the-sink unless it's impractical.
I run my RO waste water back into my water tank. Zero waste.
way2roll wrote:
Some - if not most of you - probably think it's way overkill.
Hardly. Here's my water filtration system:
A = Watts pressure regulator + separate back flow preventer.
B = Big Blue 5-micron sediment filter. Why 5-micron? Because that's the smallest recommended size that can be cleaned over and over.
C = Big Blue carbon block filter.
D = Water softener.
E = Water flow meter (for the UV filter).
F = 8 GPM UV filter.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
Page of 6
