RV.Net Open Roads Forum: 240V from 120V generator
Groover
Pulaski, TN
Posted: 06/03/19 05:35am Link  |  Quote  |  Print  |  Notify Moderator
I would love to be able to use the 6KW quiet diesel in my motorhome as a backup generator at the house. One problem is that the house needs 240V while the generator makes 120V. I have not had good luck finding 120V to 240V transformers. I am not an electrician but I remember something about isolation transformers changing the phase of the current but I don't remember if it is 180 degrees which is needed to make to 240V or only 90 degrees. Anyway, is there anyone out there with experience on this that has a good solution? I would like to be able to supply 4kw at reverse phase in case the load is off balance in the wrong direction.
DownTheAvenue
Sunny South
Posted: 06/03/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
You can feed both 120 volt legs of your house by jumping the one hot leg over to both legs off the house. You will not have 240 volts to power things like the stove, dryer, A/C, but both legs of the house power will be charged with 120 volts.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/03/19 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Good solution is to not power any of the 240V items...turn all those breakers off and do the above.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
pianotuna
Regina, SK, Canada
Posted: 06/03/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Get a manual transfer switch: https://www.homedepot.com/p/Reliance-Con........t-Manual-Transfer-Switch-A510C/206503336
Regards, Don
D.E.Bishop
Eagle Rock, CA
Posted: 06/03/19 07:16am Link  |  Quote  |  Print  |  Notify Moderator
If and when you rig things so you can use your RV genny for your home, remember that for safety's sake, install a transfer relay or manual switch in your home service. If you don't you WILL back feed power into the utility's grid and that could injure or kill some one. If you don't understand what to do, hire an electrician.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
cavie
Posted: 06/03/19 07:37am Link  |  Quote  |  Print  |  Notify Moderator
call an electrician. Have him install a Generator lock out to match your house panel. You cannot supply 240 volts from your gen. You will have access to any 120.
w4phj
Vero Beach
Posted: 06/03/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
X2
2005 Bounder 37U Cat C7 Engine
2014 Jeep Grand Cherokee Limited
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
time2roll
Posted: 06/03/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
What do you have that is 240 volts and critical? I would thing the fridge a few lights and a few outlets would be fine in an emergency. Furnace should run on 120 power. Retreat to the RV if you need air conditioning or to cook. +1 to get an electrician to look at it.
675w Solar pictures back up
Groover
Pulaski, TN
Posted: 06/03/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
AC, furnace and well pump. I don't have any built in fossil fuel heat. Giving out of water would be the most painful.
Ivylog
Posted: 06/03/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Probably easier and not any more expensive to buy a 4K generator that puts out 240V.
