RV.Net Open Roads Forum: Trying to diagnose a loud rattle coming from the floorboard
 > Trying to diagnose a loud rattle coming from the floorboard
HyvaGroup
South Carolina
Posted: 06/03/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
I am trying to find where a loud rattle noise is coming from on my 2005 Winnebego Itasca 31` E-450 with only 22k miles.
The noise starts after about 30 minutes of driving on the highway mainly when accelerating. Engine is running smoothly and has recently been serviced by certified mechanic. I,ve checked the metal shields on the exaust system but not found anything loose that would cause the rattle sound.
Thank you for any ideas.
Jay Pat
Round Rock, TX
Posted: 06/03/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
No experience here.
Possible motor mount failure?
What happens with hard acceleration in lower gears?
Pat
2010 Ford F-350 SRW
2021 Grand Design Reflection 315
garyhaupt
Penticton, BC..land of wine, sun, retirees....
Posted: 06/03/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I had such a rattle...was an exhaust hanger. Try to replicate the experience...run it up...and then climb under and touch every item with a long-ish metal bar..like a screw driver.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
klutchdust
Orange, California
Posted: 06/03/19 10:03am Link  |  Quote  |  Print  |  Notify Moderator
My thoughts, it takes 30 minutes to appear gives the impression it's heat related. I would start right from where the exhaust pipes leave the engine compartment and inspect each connecting point,especially the heat shields.
Catalytic converters will rattle once they warm up IF the ceramics have broken loose.(rare).
My 08 Jeep had such a problem, drove me crazy, only after it warmed up. Believed it was converter. Took it to a muffler shop, where the pipes crossed over there was a metal skid plate, it had a broken weld. Why only when it was warm was a stumper even for the muffler expert.
My guess is it's the shields. Get a mirror and a flashlight and get under there OR get a shop to inspect on a lift.That's money well spent.
ksmoody
Meridian, ID
Posted: 06/03/19 11:18am Link  |  Quote  |  Print  |  Notify Moderator
On my 2008 Fleetwood 31' with the E-450 engine I also had a bad rattle at highway speeds. It was a loose plastic engine shroud on the bottom of the engine. I took it off and the rattle stopped. One day I will put the engine shroud back on with new plastic clips.
pnichols
The Other California
Posted: 06/05/19 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
I've had the exact rattle for years in my 2005 E450 motorhome chassis. It started after we had owned it for a couple of years maybe with 15K to 20k miles on it - just like the OP.
EVERYTHING has been checked by me and others down there underneath ... all shields, mounts, brackets, torque converter cover, etc..
I'm convinced that it's probably some of the guts of the catalytic converter loose/broken and rattling at certain speeds and/or heat conditions. If catalytic converters didn't cost so much, I'd just replace it to get rid of the occasional racket. However, it seems like in the last year or so that the rattling has maybe lessened a bit and is not so irritating. (By the way, alternatively, is there some kind of a resonater in the exhaust line that could have loose parts rattling around inside of it?)
I'm very interested in what the OP discovers it is if they pursue it all the way, including installation of a new cat converter.
Phil, 2005 E450 Itasca Spirit 24V
Gjac
Milford, CT
Posted: 06/07/19 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Also there are baffles inside the muffler that get rusted and can come loose. I would tap on the muffler, cat and resonator if you have one and see if it rattles.
garyhaupt
Posted: 06/08/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Depending on your states vehicle testing....one can have the cat converter removed. They are a in constant state of deterioration.
Gary Haupt
MR MAC
South East MA
Posted: 06/09/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if this the same thing but my MH sounded like symbols. It was the shields , I bought "S" strips, cut and drilled holes pushed them all around the edge of the shields, screwed self taping screws in and that was it. Hope his helps.
ROBERT L MC INTYRE
pnichols
Posted: 10/18/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder it it's the infamous E350/E450 serpentine belt "rattle"?
This has been discussed a lot in the Ford owners forums. I believe the solution has something to do with an additional, or different, idler pulley between installed at a certain place in the belt's path so as to better support the belt at certain engine speeds.
