RV.Net Open Roads Forum: Dometic refrigerator keeps tripping the thermal limit switch
 > Dometic refrigerator keeps tripping the thermal limit switch
Flinx777
Murrieta
Posted: 06/03/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2003 dometic refrigerator, RM2652, with an updated panel (update done in 2009 as it had originally been recalled). I just bought the rv used a few weeks back and upon plugging it in to power the refrigerator, the thermal limit switch keeps tripping. I'm not using propane, but rather shore power. As a result, the refrigerator keeps shutting down.
I replaced the 5 amp and 3 amp fuses a few days ago on the replaced circuit board as they were no longer functional.
Anyone else run into this issue or know of a solution to resolve the issue?
* This post was edited 06/03/19 08:39pm by Flinx777 *
2000 Ford 350 DRW 7.3L Turbo Diesel, 4 speed automatic, 4.10 rear end, limited-slip differential. Banks Power & Brakes, B&W Hitch
2007 Keystone Montana Mountaineer 34pht
BFL13
Victoria, BC
Posted: 06/03/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
The pros will be here soon, but first, please clarify that you have a new "main board" (replaced by you?--why?) and now the new board has both the 5a (for 120v) and the 3a (for 12v) fuses blown.
What is the sequence of events exactly? It matters for figuring this out.
Have you had it working on propane (requires 12v to work the fridge controls)? Still works on propane now you replaced the 3a fuse?
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Joe417
AL
Posted: 06/03/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't looked at a Dometic in years. Not sure what you mean by thermal limit switch. My Norcolds don't have one that I know of. I've heard other talk about an aftermarket limit device, not sure how it works.
You didn't put your model number in the post. These guys need that to give you more specific info.
The 5 amp is probably for the AC electric heating element. 3 amp for the controller board. Both fuses being blown is a bit confusing.
If your controller board isn't getting power you can't run on gas either.
When you replaced the fuses, did they blow again?
You need to measure the resistance of the heating element. They vary depending on the model. All of mine were around 300 watts. Which would be about 50 ohms.
That would make normal operation around 2.5A. If your blowing the 5A fuse yours would be around 25 ohms or less.
Joe & Evelyn
Flinx777
Murrieta
Posted: 06/03/19 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
I think I have discovered the issue. Spoke with a local RV repairman and he asked if there was any yellow / green fluid that had leaked behind the refrigerator. Sure enough, it can be seen here:
https://www.dropbox.com/s/7q1msqr9j5acr4s/2019-06-03_19-33-53.png?dl=0
He informed me that the refrigerator is shot at this point and will be have to be fully replaced as the coolant has leaked out. Bummer [emoticon]
I'll post a response to some of the questions earlier in a moment.
DFord
Near St Louis, MO
Posted: 06/03/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, that's the end of that cooling unit. The yellow color is from chromemate which is in the solution along with ammonia inside the refrigerator. The boiler has failed. Perhaps from constant overheating from operation with the RV out of level. The thermal sensor tripped because the heater was heating the boiler but that heat wasn't being carried away as would happen if it was working normally.
The cooling unit can be replaced without replacing the whole refrigerator but the difference in cost isn't all that great and you'll only save money if you do it yourself because of the extra labor of taking the refrigerator apart and putting it back together again as opposed to pulling the old refrigerator out putting an new one back in.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Old-Biscuit
Verde Valley
Posted: 06/03/19 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Yellowish residue.......sodium chromate (rust inhibitor in coolant solution)
The dried residue is TOXIC
Do NOT use air compressor to blow it out
Gloves, eye protection, vacuum ----wipe down with wet cloths (dispose of them in a sealed zip lock bag)
garyemunson
Reno, Nevada
Posted: 06/04/19 05:03am Link  |  Quote  |  Print  |  Notify Moderator
Over the decades I've had to replace 2 cooling units. Both were in RVs I bought used so I suspect they were not operated correctly in the past. Since I've done them myself (pretty easy as they were older, smaller fridges), it was far cheaper than replacing the entire fridge. At this point, you should take stock of how you use your RV. If you always go to RV parks wth hookups (nothing wrong with that, lots of people prefer the comforts provided!) it's time to switch to a residential type fridge. Cheaper than repairing yours even if you do all the work yourself. If you boondock at all or go to state/national campgrounds without hookups, gas fridges are still king. Switching to a residential in those cases usually involves more batteries and an inverter upgrade so you end up spending the same or more. As said above, operating out of level can make fridges run hotter outside increasing the risk of springing a leak from the repeated flexing of the steel from the greater temperature swings. You don't have to be spot on level, what happens occurs on a "sliding scale", the more out of level, the hotter the coils run. Just do your best to get the coach not too far off level and you will be OK. I've seen the obsessed using a 3' level feverishly adding/subtracting blocks to get their rig perfect. Not necessary. Also, if you live in a humid climate, leaving the RV plugged in and the fridge on electric will keep the outside coils hot and lessen chance of them rusting out at one of their welds.
https://rvcoolingunit.com/Dometic-Cooling-Units-remanufactured-C4380.aspx?sid=298
dougrainer
Carrolton, Texas
Posted: 06/04/19 05:20am Link  |  Quote  |  Print  |  Notify Moderator
The Thermal fuse WORKED. That is why there is a Thermal fuse. It shut the refer down because the cooling unit overheated due to NO Ammonia and had leaked out. Doug
Flinx777
Murrieta
Posted: 06/04/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Good to know...thanks! Will definitely not touch it and will be careful when handling it.
Flinx777
Murrieta
Posted: 06/04/19 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Yup, same thing the tech said yesterday [emoticon]
