RV.Net Open Roads Forum: General RVing Issues: Fireplace heater beeping
 > Fireplace heater beeping
roaminaround
Bend, OR
Posted: 06/03/19 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
We have a new Rockwood with a Titan electric fireplace heater. Every time you hit a button on the unit or the remote it beeps loudly. I've read online about disabling or removing the piezo speaker and wondering if anyone has done this. I assume this would void my warranty but I really don't care. It's driving the dog crazy.
2019 Rockwood 2608BS
2018 Ford F250 6.7 diesel
2006 Fish Rite 18' Yamaha 115 and T8
Fizz
Ottawa, Canada
Posted: 06/04/19 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Try stuffing a cotton ball in it to muffle the sound.
ppine
Northern Nevada
Posted: 06/04/19 10:39am Link  |  Quote  |  Print  |  Notify Moderator
An example of options that are more trouble than they are worth.
Wherever I happen to park
Posted: 06/04/19 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have taped over pizo deices to mute them but usually.. They come in two types.
PC Mount.. now disabling those has to be done very carefully. Basically unsolder and remove
Wire lead type Often if you trace the wire back to the PC board there is a plug. Simply unplug.> NOTE you an get a "less noisy" one and plug in
Option 2 is cut a wire and tape the ends both off. and together but not touching
Do it so it is clear what has been done.
Home is where I park it.
roaminaround
Bend, OR
Posted: 06/06/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
So I disassembled the unit and found the piezo. I carefully drilled out the back of it till the back came off. I saw a foil diaghram and removed it. Beeping is 100% gone. Reassembled and tested. Success
Dtank
Posted: 06/11/19 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Now you just need some wood for the fireplace - and turn the AC "up"..[emoticon]
StirCrazy
Kamloops, BC, Canada
Posted: 06/11/19 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
mine has a button to turn the beeps off.....
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
