RV.Net Open Roads Forum: Tech Issues: Drawing water from a lake
 > Drawing water from a lake
Page of 17
swimmer_spe
Sudbury, Ontario, Canada
Posted: 06/03/19 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Soon, my current TT will be up on blocks at a seasonal site. There is no water system at the park. Because of this, I plan to fill my fresh water tank with lake water.
How can I do this to ensure safe drinking water.
rk911
Wheaton IL
Posted: 06/03/19 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
read up on water purification.
be certain you know what you're doing or be sure you have cell service to call for an ambulance.
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Dutch_12078
Winters south, summers north
Posted: 06/03/19 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
When we're boondocking by our favorite stream fed pond in the Adirondacks, we use a "LifeStraw Mission" to filter the pond water for our drinking water. All the other pond water we use for showers, etc., runs through a dual whole house sediment and carbon block filter before entering the motorhome water system.
Dutch
2001 GBM Landau 34' Class A
swimmer_spe
Posted: 06/03/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
OP here. The water is safe to drink. I just want to make sure it doesn't have anything in it that could cause issues, such as sand, debris and of course the bacteria and viruses.
GordonThree
Northern Michigan
Posted: 06/03/19 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
What does that mean?
Who told you that the water is safe. Do you trust that source with your life?
I'd go with a coarse filter, fine filter, RO membrane and then UV. Might want a high pressure booster pump for the RO if the water is high in TDS.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
doxiemom11
Paris, MI
Posted: 06/03/19 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
I'd buy bottled water to drink, make coffee and maybe cook with. We don't usually buy our water, but in this case that's what I would do.
swimmer_spe
Posted: 06/03/19 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I trust the source with my life. I have drank it many times with no issues. The issue I am concerned with is it sitting in a tank and pipes for a period of time.
swimmer_spe
Posted: 06/03/19 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
If that is what is needed, I will just bring tap water from home.
rk911
Wheaton IL
Posted: 06/03/19 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
pardon me but if it was safe to drink you wouldn’t be worried about sand, debris, bacteria and viruses. good luck.
swimmer_spe
Posted: 06/03/19 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
It is coming from a lake, so sand and debris can be sucked up, even if the intake is floating midway in the water column. If water sits, it could have something in it that could grow from a benign level to a dangerous level. Even your safest water has some things still in it, but at levels that are harmless. Since the water could be sitting for weeks or months at a time, I want to make sure it stays safe to drink when I turn on the taps.
Page of 17
