RV.Net Open Roads Forum: General RVing Issues: What to use to brighten rv?
 > What to use to brighten rv?
suprz
rhode island
Posted: 06/04/19 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
What do you use to brighten the outside of your RV (typical filon gelcoat siding) to me it looks dingy and not bright anymore
* This post was edited 06/04/19 02:09pm by suprz *
Proud father of a US Marine
Monterey, California
Posted: 06/04/19 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I wax at least twice per year...front more often. Keep it covered when not in use. Fiberglass has as much shine as it did four years ago. I'm a Mother's fan.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
2oldman
New Mexico
Posted: 06/04/19 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Probably a good wash job followed by a lot of wax. Seems to be a few youtubes on this. "rv looks dingy"
suprz
rhode island
Posted: 06/04/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I have already washed it, as I usually do, but I just feel like it isn't the bright white it was. I always wax it. I'm just hesitant to wax over the dingy old finish
FLY 4 FUN
Alberta
Posted: 06/04/19 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
depending on how old the unit is there might be oxidation that is tarnishing the finish. In that case you may need to use an rv polish, then wax the rig to bring up the shine. The elements are not kind to our toys!
* This post was edited 06/04/19 04:50pm by FLY 4 FUN *
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
doxiemom11
Paris, MI
Posted: 06/04/19 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Wax build up will yellow with heat. You probably need to strip the old built-up wax off and start with a fresh 1st coat. I discovered this when I was using LA Awesome trying to clean black streaks and it removed the old wax - big job though.
Sprayed on straight, let it sit a minute or two, scrubbed with soft sponge with elbow grease then rinsed immediately working small areas at a time.
wildtoad
Blythewood, SC
Posted: 06/04/19 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Barkeepers Friend in a trial area will do a good job on getting it clean.
Tom Wilds
Blythewood, SC
dpgllg
South West Pennsylvania
Posted: 06/06/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
I used this on my old 5th wheel and it took off most of the oxidation.
2013 2500HD Chevy LTZ 6.6 Diesel Ext Cab Long Bed
2017 Grand Design Reflection 27RL 5th Wheel
Dear Wife, plus two Cocker Spaniels and a Standard Poodle
Veebyes
Posted: 06/06/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
A little confused on what you have. Gloss gelcoat or non gelcoat filon that you can see the glass chop strand through? Either one requires a good cleaning with something like Barkeepers Friend or Zud first to remove grime & oxidation. For gelcoat the next step is a good cleaner wax like 3M followed by a good fiberglass wax like Meguires Flagship wax. For the filon siding I would use something like 303 protectant. For best results it is very important to clean the surface well.
2007 Alpenlite 34RLR
Posted: 06/06/19 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Try reading the 100 threads about oxidized finishes on here.
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
