RV.Net Open Roads Forum: Fifth-Wheels: Fiberglass blistering
 > Fiberglass blistering
bc3309
NY
Posted: 06/04/19 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2015 Keystone Outback 5th wheel I purchased new. It has blistering on the sides. It looks like spot welds that have popped under the fiberglass coating. Getting it fixed is not going well. Anybody else having this issue ?
Hearst San Simeon State Park
Posted: 06/04/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Have you reported this to Keystone with pictures?
Winnebago 2101DS TT & 2019 Chevy Silverado 1500 LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - (MOS 1542 & 1560)
downtheroad
Pacific Northwest
Posted: 06/04/19 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum.
Sounds more like you may have a de-lamination issue.
Hard to give advice without more info.
Can you post a picture?
Use this........Picture Posting Tool
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Veebyes
Posted: 06/04/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
In the marine world it is referred to as boatpox. Various causes ranging from resin used to air temp at layup. The remedy usually is to grind each blister out, fill it, fair it, & regelcoat it. Simple but labour intensive.
2007 Alpenlite 34RLR
bc3309
NY
Posted: 06/05/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
The dealer has told me Keystone is not standing behind it. I have coverage for this but the process the dealer has used on some other campers with the same issue is not working out
Johnnybgood
Illinois
Posted: 06/06/19 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like what we just had repaired on our Triple E. They had to cut out the sections that were affected and replace them. Not cheap. But looks much better.
BillyBob Jim
US
Posted: 06/06/19 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Its not a boat. The fiberglass layer is @ 1/16" thick and boded to a layer of 1/8" thick luan plywood, which is bonded to the center structural layer composed of aluminum tubes infilled between with beaded foam, followed by the inner layer which is more 1/8" luan plywood with vinyl wall-covering. Keystone does not vacuum bond their wall panels, they pinch roll.
Are you sure you are not seeing too long of screws used to mount interior items such as cabinet cleats, which in turn pushed out the outer layers braking the adhesive bond? Its fairly common and easy to find examples on any dealer lot.
Repairing defects or delamination on a laminated wall is problematic. Epoxy injection can work depending on where the area is located and done by someone who knows how. "Cutting Out" sections is a shoemaker type band aid repair. A good body man may be able to get it sort of non noticeable, but it's always going to be visible as a repair, especially given some time and expansion and contraction.
It's not unheard of for manufacturers to take rigs with lamination defects back to the factory and replace the entire wall panel. Unfortunately you are dealing with Keystone, and I know what that is like from owning one. They'll do everything they can to get out of a warranty repair. Good Luck.
Rwake901
Central, Illinois
Posted: 06/06/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
There’s the quote of the day and how true it is!
Rich&Mar
wa usa
Posted: 06/07/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
2x above, my advice, which I will follow next time, is to try and not buy another keystone product if I can find something else. their c.s. sucks!!
rich
4x4ord
Alberta
Posted: 06/07/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
What is happening to your trailer is called osmosis blistering. It is the result of a small amount of moisture getting into your wall. The moisture wicks it way out through the slightly porous fiberglass by osmosis until it reaches the impermeable layer of gel coat. The blister is formed and pops to let the moisture through. The first step in the repair is to reseal the window or roof or wherever the moisture is finding it's way behind the Filon. The next step is insure the Filon has thoroughly dried. Finally the damaged surface can be repaired.
If the source of moisture getting to the back of the panel is not eliminated the problem will reoccur.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
