RV.Net Open Roads Forum: Travel Trailers: Vintage TT needs stabilizing, but stumped
Open Roads Forum  >  Travel Trailers  >  Vintage TT's
 > Vintage TT needs stabilizing, but stumped
coachellacanuck
Alberta
Posted: 06/05/19 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
afidel wrote:
coachellacanuck wrote:
Chris Bryant wrote:
Jack stands, one at each corner. Crank the tongue down a bit, put stands under the rear, crank it up a bit past level, put stands under front,
Not sure what jack stands refers to... those plastic “LEGO” blocks?
No, the kind of stands you use to change a tire at home.
Ah. So “scissor jacks”! I wondered if those would work. Thanks!
BarneyS
S.E. Lower Michigan
Posted: 06/05/19 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Inexpensive jack stands.
A bit better ones from Harbor Freight.
A variety from Northern Tool.
Barney [emoticon]
* This post was edited 06/06/19 08:38am by BarneyS *
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
coachellacanuck
Alberta
Posted: 06/05/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks! Will search for similar in the area.
fly-swatter
Alberta, Canada
Posted: 06/05/19 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
If you're in Edmonton, head on over to Princess Auto or Canadian Tire. They will have lots to choose from.
2012 Ram 2500 Hemi
2012 Flagstaff 8524RLS
OleManOleCan
Alabama
Posted: 06/05/19 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
Jack Stands are an economic solution.
A couple of years ago I used 4 on a Scotty. Worked very well.
Lowering the tongue raises the rear of the camper.
Insert jacks under metal and raise em till they are touching or nearly touching.
Raise the crank and it puts weight on the rear jacks.
Put jacks under the front, near the tongue, and lower the crank a little,
and your camper is sitting on 4 jack stands.
No rock and roll when you walk inside.
It's quick and easy to use Jack Stands.
Harbor Freight has em two to a pack. Decent price.
dodge guy
Bartlett IL
Posted: 06/06/19 09:11am Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
Look for the small flip down style pop up camper jacks.
Not sure what flip down jacks look like. Scissor jacks?
Like these! Flip down jack.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
