RV.Net Open Roads Forum: General RVing Issues: Finding Exterior Wall Studs
 > Finding Exterior Wall Studs
1L243
Oregon
Posted: 06/05/19 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
I did post this question several months ago but got no reponse so, I thought I would throw it out there again.
I have a aluminum sided trailer with wood construction. I would like to locate the exterior wall studs. I have a quality electronic stud finder and I have tried the magnet and knocking method with no results.
I can locate the wall studs on the inside of the trailer with the stud finder and transfer that to the outside but this does not work when cabinets and appliances are in the way.
What's your method for finding exterior wall studs.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
CA Traveler
The Western States
Posted: 06/05/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
On a cool morning I took pictures of the condensation patterns on the outside.
2014 Grand Cherokee Overland
Bob
myredracer
Langley B.C.
Posted: 06/05/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure why you need to know stud locations, but you can try tapping with a nylon faced hammer on the exterior skin. If you look inside upper and lower cabinets you may see where they ran screws through 1x1 into the studs. *If* you can make an assumption that studs go from floor to ceiling, if you look closely, you can find the tiny staples at go through the luan plywood into the studs.
Or if you get a IR gun, you might be able to easily tell where there's a temp. diff. An IR gun is a good tool to have anyway.
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
shepfly
NW Ohio
Posted: 06/06/19 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Lookup Walbot , it attaches to a smart phone and allows you to see what's inside a wall. I haven't used this device. Dave
colliehauler
Mc Pherson KS USA
Posted: 06/07/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
As another poster said very easy look on a cool morning with condensation each stud will have a pattern on the siding where it's located.
mike brez
Unknown
Posted: 06/07/19 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Here
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
1L243
Oregon
Posted: 06/07/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Both look like great devices but I wonder if they work through aluminum siding. I have a decent electronic stud finder that works great inside the trailer and on dry wall but does not work at all on the outside aluminum skin.
I have tried the IR gun but it did not show any variance but that said I did not have the heat on inside the trailer and I think that may be necessary to see temperature changes.
CA Traveler
The Western States
Posted: 06/07/19 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Using the condensation pictures as a guide measuring and determining stud locations inside and outside is easy.
* This post was edited 06/07/19 10:44am by CA Traveler *
