RV.Net Open Roads Forum: Attaching screws to aluminum floor joists
 > Attaching screws to aluminum floor joists
DavinD
Litchfield Park, AZ
Posted: 06/05/19 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Short Version - Is it ok to use self-tapping screws to attach items to the aluminum floor joists on the ceiling of my basement.
Long Version - Like most basements, mine has a thin divider "protecting" the pluming and wiring from the stuff I store in the basement. That divider is only attached at the floor of the basement and on the two outside walls. In addition, they left a lot of open space in the "protected" area that can be used for storage if I clean up a few wires, etc. When I reconfigure this divider, would it be ok to attach wood framing to the underside of the aluminum floor joists to give the divider better support at the top. I would likely use self-tapping screws.
2018 Coachman Chaparral 381RD
TV - 2013 Ford F350 Diesel SRW 4x4 Short Bed
tbr2015
Rockford, MI
Posted: 06/05/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Can’t see why that would be a problem. I have done it on mine to attach things to them.
SDcampowneroperator
South Dakota
Posted: 06/05/19 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
electrolitic corrosion happens between dissimmilar metals. Maybe use aluminum pop rivets instead?
owenssailor
Ontario
Posted: 06/05/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a dry location corrosion should not be a problem. On our boat there are Stainless screws into the aluminum masts. They get wet and then dry. They have been there for 56 years and are still all fine.
2011 Jayco 28U
2012 Chev Silverado Crew Cab 5.3 6 spd 3.42 (sold)
2017 Chev Silverado Crew Cab 5.3 8 spd 3.42
Equal-i-Zer 1400/14000
RotoChocks
naturist
Lynchburg, VA
Posted: 06/06/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
I would not expect electrolytic corrosion to be much of a problem generally with aluminum because of the aluminum oxide that always coats the aluminum. Certain conditions (such as in car cooling systems with the wrong coolant) being exceptions. If the OP’s screws stay dry, or see only fresh water at near neutral pH, there should be no issue with electrolytic corrosion.
Dusty R
Charlotte Michigan 48813
Posted: 06/06/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Perhaps insert plastic concrete anchors in the aluminum and then the screws into the plastic anchors.
Cummins12V98
on the road
Posted: 06/06/19 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Plated screws are FINE!!! I would suggest trying sheet metal screws first as the driller screw will remove a lot of material and the aluminum does not have the holding power as other metals.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Hammerboy
Zeeland, MI
Posted: 06/06/19 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
I did to my current and past units and not a hint of a problem. As said if it's dry you wont have a problem.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
DavinD
Litchfield Park, AZ
Posted: 06/06/19 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the replies. If my basement ceiling gets wet, I've got bigger problems. [emoticon]
mapguy
Puget Sound
Posted: 06/07/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Use rivet nuts -that way you can r&r the dividing panels an endless amount of times. With sheet metal screws -you will get a limited amount of r&r's before threads are gone and larger screws are needed.
