RV.Net Open Roads Forum: Fifth-Wheels: Feet on landing gear
 > Feet on landing gear
Jkmrich
CA
Posted: 06/06/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
We have the rectangular feet on our landing gear. Does switching to the round 9” feet make a difference? (More stable)
Roger10378
Goodrich, MI.
Posted: 06/06/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Probably not. You will see a much bigger difference if you put one of the systems on that triangulate the legs.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
agesilaus
North Florida
Posted: 06/06/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Doubt it, why would it??
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Durb
NW
Posted: 06/06/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my landing gear pads with ones that were larger and heavier duty, however still rectangular. They didn't add to the trailer's stability. What did help was putting the landing gear on 7 1/2" high blocks. These shortened the landing gear legs and took some shake out of the trailer.
Jkmrich
CA
Posted: 06/06/19 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Like wood blocks or some type of commercially made block? Thanks!
RobWNY
Jamestown, NY
Posted: 06/06/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Either wood blocks or commercial made ones will work. I use the Lynx Levelers. A full package of 10 for each side. In my case, I didn't want the extra weight wood has. I was really surprised how much more stable the 5th wheel front end is when the landing gear isn't extended much.
time2roll
Posted: 06/06/19 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have some wood to put down if the soil is soft or to keep them off frozen ground.
675w Solar pictures back up
wrgrs50s
Scurry, Tx
Posted: 06/06/19 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
The slack in the extension part of the legs is what causes the movement. The foot size will only help the foot from sinking into the ground somewhat.
As stated before, the less the leg extends the less slack present, however there may be some risk in damage if they fell off the blocks due to wind storm or while hitching up.
I usually stack 2 pieces of 2 x 6 under each leg and use the X chocks and that helps somewhat with the rocking fore and aft.
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
Old-Biscuit
Verde Valley
Posted: 06/06/19 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
6x6x6 wood blocks with rope handles
One under each front landing gear
One under each rear stabilizer jack
Spreads the weight out over larger distance AND keeps the landing gear/stabilizers from having to extend as far
I just carry them in bed of truck behind tailgate....along with 2 2x10 boards for leveling side to side (one 52" long and one 48" long...45* cuts on each end)
KMLsquared
Cotati CA
Posted: 06/07/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
It you want more stability, add the triangulated links to your landing gear. I made my own and the improvement was huuuuugggeee! I added larger feet to mine so I would not need to carry around extra blocks for support on soft ground.
2002 HO 6spd LB QC 4x4. Edge Juice w/Att 4" str8 pipe AFE int Skyjacker D25 springs w/10" Fox Shox 2.0 Thuren track bar PSC Steering box w/DSS. Fox Steering Damper w/custom mount.
2003 Rampage 33TB
2002 Banshee
1969 Baja
