RV.Net Open Roads Forum: Truck Campers: Installing Progressive Dynamic converter
 > Installing Progressive Dynamic converter
TxGearhead
Posted: 06/06/19 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe a month ago I bought a Progressive Dynamics converter to replace the OEM in my 2008 Bigfoot. I had a book of Electrician numbers to label the wiring. After removing the wiring I began hooking up the new DC panel/fuse board. The positive battery cable lug on the new board was located a couple inches different than the original. No matter how hard I pulled or manipulated the new board, there was no way I could get the wire on the lug. I got so frustrated I re-installed the OEM.
I called the seller, Best Converters, and asked if there was an easy way to add a few inches to that heavy battery cable. They said to use anything, even a wire nut. I asked about a heat shrink butt splice, sure that's fine. Any "best practice" ideas here? Butt splice, crimped on eyes for a bolt and nut? I'm thinking I'd rather not use a wire nut. I'm not sure of the wire gauge, probably about .250".
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Joe417
AL
Posted: 06/06/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
It's 6 AWG.
The average crimpers don't do a good job for me so I usually solder the splice and the lugs and heat shrink anyway.
That way no question about the connections.
Hardware store probably has a butt splice that will fit if you have the crimpers large enough to do the job.
Joe & Evelyn
AnEv942
CA
Posted: 06/06/19 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
My 1st thought, as ours is only a few feet from battery, would be replace cable with a longer one. Would also be the least restrictive to its length.
A box with stud where you could immobilize both cables.
ANL fuse or reset-able breaker would make good 'junction' to add cable. Rated higher than what might be at either end.
Last option would be nut & bolting eyes of cables together, I wouldn't, invariably will loosen. If you need to, add extra so you can zip tie the cables together, put in a box.
Our camper projects page
time2roll
Posted: 06/06/19 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
I would use a butt splice to extend the wire. Preference would be to reposition something or find some slack. Or just pull new wire.
http://www.genuinedealz.com/marine-electrical-supply/wire-connectors?cat=170
675w Solar pictures back up
BradW
Mayor of Flat Rock
Posted: 06/06/19 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/Dorman-85261-6-Gauge-Butt-Connector/dp/B00A0FZW7G
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
BradW
Mayor of Flat Rock
Posted: 06/06/19 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/Z-Red-B790C-Hammer-Crimper/dp/B000M7LFKK
Bradymydog
Western MA
Posted: 06/07/19 04:57am Link  |  Quote  |  Print  |  Notify Moderator
I'm very interested in how you make out as I have the same camper and am considering the same mod.
Chris Bryant
Arden, North Carolina
Split bolt connectors are bullet proof-
-- Chris Bryant
midnightsadie
ohio
Posted: 06/07/19 05:15am Link  |  Quote  |  Print  |  Notify Moderator
some good advice,me I,d run a new cable.
ppine
Northern Nevada
Posted: 06/07/19 08:24am Link  |  Quote  |  Print  |  Notify Moderator
A new cable should be easy.
