RV.Net Open Roads Forum: Travel Trailers: Leveling blocks
 > Leveling blocks
Varmintmist
West PA
Posted: 06/06/19 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, newbie question. Since I am a newbie, it only seems right.
2x6 or 2x8? 3 or 4?
I had a little time tonight so I did the setup for loading and driveway camping test run. I had 2x4's so she is leveled with those. I think 2x8s would give me a bit more room, and take up a bit more room in storage and I am pretty sure I can hit the 2x6's. Looked at the Lego blocks, and 45+- bucks for them offends my Scottish side and I dont see a compelling reason to spend the cash beyond weight.
Always cross your chains and grease your balls
07 F250
2019 Surveyor 27'
Mojave, Kern County, California
Posted: 06/06/19 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
I use 2x8s to make it easier to get the entire tire on the block.
sh4717
Las Vegas
Posted: 06/06/19 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Here’s what I did. They work great. I cut them so they would fit in a milk crate for easy storage.
https://m.youtube.com/watch?v=6c2nFUeD6nA
Scott
2019 Northwood Nash 24M
2018 Ram Ecodiesel
Lynnmor
Red Lion
Posted: 06/07/19 03:17am Link  |  Quote  |  Print  |  Notify Moderator
Blocks should be at least as wide as the tire tread when used under the tires. Stabilizers should be set on blocks wide enough that they don't sink into soft ground. You should have several blocks for the tongue jack. I carry about 16 wooden blocks and a set of legos and have used all of them on some uneven PA campgrounds.
prichardson
Lafayette, La
Posted: 06/07/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
An 8' 2x8 from the local building supply cut into 8" squares will give you a nice supply of blocks.
RobWNY
Jamestown, NY
Posted: 06/07/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Great idea but heavy. About 100 pounds! I've been using Lynx Levelers for the landing gear and rear jacks and Andersen Levelers for under the tires. No issues over the last 5 years and maybe 20 pounds total weight.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
ppine
Northern Nevada
Posted: 06/07/19 08:21am Link  |  Quote  |  Print  |  Notify Moderator
2x6s work fine but they split after they are driven on for awhile.
Bevel the edges.
I like the plastic blocks and mostly use those.
maddog348
Bakersfield,CA
Posted: 06/07/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Rob is right ~ they are heavy~~
Prichardson ~` a stack of 8" blocks is great. BUT how to you get your tires up on them???
JM2¢ ~~ YMMV
fdwt994
Indianapolis, IN
Posted: 06/07/19 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
To each his own, but the lego blocks we use have lasted us almost 15 years now with no signs of deterioration. We love them.
Good luck in your decision.
2018 F250 6.2 Crew Cab
2018 Salem Hemisphere GLX 312QBUD
A family who loves to camp!
GrandpaKip
Flat Rock
Posted: 06/07/19 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Andersen type levelers (home made), 6 pcs. of 1/2”x 12”x12” marine plywood, a 6x6x16, and a couple of 2x6x8”, and 3 sets of lego blocks have served us well for years. All the wood fits in a milk crate and the blocks hardly take any room in the pass through.
We do spend most of our time in state and national campgrounds where the sites are not terribly unlevel.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
 > Leveling blocks
