RV.Net Open Roads Forum: Travel Trailers: Leveling blocks
 > Leveling blocks
westend
Shorewood, MN
Posted: 06/08/19 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW, I raid construction dumpsters (I ask permission, first) for LVL scraps. The engineered wood is not prone to rot and won't break if you hit it with a sledge hammer. A couple of longer pieces, cut into blocks and leaving one or two longer with angle cuts serves well. The LVL is typically 8" or greater in width.
'03 F-250 4x4 CC
IAMICHABOD
Sunny So Cal 90713
Posted: 06/08/19 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Vintage465 wrote:
Anyone have any ideas why my pics don't show. I uploaded them like I always do and I got a nasty gram in red say I didn't follow protocol. So I uploaded them with the little icon image thing on the tool bar and it loaded like that above.
Did you use This method of posting pictures?
I just did and it worked fine.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
Vintage465
Prunedale CA.
Posted: 06/09/19 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
Yup I did. Been using that upload link for a couple years now I think. Seems to be the best pic-adder of all the forums I visit. I'll give it another shot.
V-465
2013 GMC 2500HD Denali, stock....for now. 2015 Creekside 20fq w/300 watts solar. Retiring in 2021, then look-out road, here we come!
Vintage465
Prunedale CA.
Posted: 06/09/19 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Vintage465 wrote:
I cut out four 4x6x12, four 2x6x12, two chocks out of rough 6x6 redwood.
[image] border="0" alt="[image]">
Then I built this box. It fits under my tonneau cover on the pickup. There is just not enough room in my little 20fq for leveling blocks
They all fit in just like this. The rope grabs are a nice feature so you can grab 4 or 5 at once to disburse them around the coach[image] border="0" alt="[image]">
Since I built this set up in 2016, I've not needed any other type leveling materials. I am pretty selective about my sites when boon docking though. I keep one set of Lego's just in case. The redwood is super light when it dries out. Durable enough since there are few if any knots.
There's the pics
OleManOleCan
Alabama
Posted: 06/10/19 12:24am Link  |  Quote  |  Print  |  Notify Moderator
ppine wrote:
2x6s work fine but they split after they are driven on for awhile.
Bevel the edges.
I like the plastic blocks and mostly use those.
When 2x6 split burn em in campfires.
I use 2x8s and have lost a couple over the years, but they are easy to replace.
librty02
Western Pa
Posted: 06/10/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Lynx Levelers hands down...Leave those big heavy chunks of wood in the lumber yard. The Lynx levelers have held up for 15 years now from the beach heat to the freezing snowy winters and I have yet to break one. $28 a set on amazon.
2011 FORD F-150 FX4 CREW CAB ECO...
2018 Ford F-150 Max Tow Crew 6.5 3.5 Eco...
2013 Keystone Passport 2650BH, EQUAL-I-ZER 1K/10K
SoundGuy
S Ontario
Posted: 06/10/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
IAMICHABOD wrote:
I tried the Lego type blocks but found that they broke to easy and were a pain to setup when you don't get it right the first time and had to drive off,re-stack, and make them higher,to labor intensive.
I solved the cracking issue by mounting a layer of Lynx to a length of 3/4" plywood that hinges in half for easy storage. The Lynx blocks won't crack regardless of the terrain they're sitting on, won't shift out of position, and provide a locked base on which additional Lynx can be set. I've used this system for years on a variety of trailers, works like a charm. After a few uses you get to know how much lift you need on the low side and I've rarely had to pull off the stack to change the height.
A series of pics illustrating how I built this Lynx / Wood leveling system starts here - click on the "i" at the top right of any pic for a text description.
Lynx / Wood Leveling System
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
rbpru
North Central Indiana
Posted: 06/10/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I take two 2x12s, each is 5 ft. long. They are heavy, a bit cumbersome and I carry them in the bed of the tow vehicle. The are stored in the TT storage compartment when not in use.
They work great.
I simply back into the campsite and when I am satisfied with TT position, I set the boards next to the low side tires. I pull forward five feet and slide one or stack both of the boards behind the wheels as needed for level; Then I back up five feet. Easy peasy.....[emoticon]
Yes, as I said, they are bulky and a bit cumbersome to store but when I am done, I have both tires sitting squarely on a one foot by five foot wooden platform, with up to 4 inches of level.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
Varmintmist
West PA
Posted: 06/10/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
WTP-GC wrote:
Classic RVer mentality (for the newbies and experienced):
"We just spent $25K on a new RV but $25 for a bag of leveling blocks that will get used on every trip is way too much money. But let's go buy a $20 board and cut it up."
The trick is to not buy it twice unless it has served its useful life. I can spend with the best of them, but I hate doing it twice for something that doesnt live up to expectations. I have blocked a lot of different things with wood on construction (low boys), car haulers, and utility trailers and I know it works. Just looking for good reasons to try something different.
FYI ordered a set of Camco blocks from Amazon. I think that those supplemented by 2x6x9's and some 4x4x9-12's and other stuff from the barn will probably get me going. Weight and moisture are good arguments for the plastic Lego's since I am going to do my best to keep trailer stuff out of the truck.
Always cross your chains and grease your balls
07 F250
2019 Surveyor 27'
Varmintmist
West PA
Posted: 06/10/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
myredracer wrote:
Varmintmist wrote:
and 45+- bucks for them offends my Scottish side and I dont see a compelling reason to spend the cash beyond weight.
Lol! Scottish background here too.
 > Leveling blocks
