RV.Net Open Roads Forum: General RVing Issues: Tire question?
 > Tire question?
pitch
NY
Posted: 06/07/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
I often see experts on here saying that if you have one flat you should change all four because of the "overloading" that occurs on the other three.
I am putting on new brakes, how do I jack it up so that additional stress won't be transferred to the "off" tires?
troubledwaters
Potomac
Posted: 06/07/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
If you stop believing everything you read on the internet you won't have a problem jacking up your trailer and installing new brakes (or whatever). What you need to be worried about is where you put the jack, not how much load is on the other tires.
BarneyS
S.E. Lower Michigan
Posted: 06/07/19 08:34am Link  |  Quote  |  Print  |  Notify Moderator
This ^^
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
Posted: 06/07/19 08:50am Link  |  Quote  |  Print  |  Notify Moderator
?? Confusing question, but if you're concerned that the other tires will be overloaded and thus damaged, in a static situation while lifting one wheel (to change brakes), they wont.
Even if you were loading the other tires more, it wouldn't matter, but you're not loading the other tires more, you're just letting the jack do the work of the tire that's off.
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
Posted: 06/07/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
And regarding the change all 4 tires after a flat, that is totally subjective and situation specific too.
BillyBob Jim
US
Posted: 06/07/19 08:57am Link  |  Quote  |  Print  |  Notify Moderator
The last time I had a flat on the trailer I changed the other 3, the 4 tow vehicle tires, my wifes 4 tires who was following me at the time, and my next door neighbors including all the spares. You can never be too safe.
DrewE
Vermont
Posted: 06/07/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Jacking one side does not (significantly) stress the tires on the other side; there isn't much if any weight transfer there. You're just taking the weight that the tires on the side you're jacking up off of those tires and putting it on the jack.
There is a very tiny bit of weight transfer due to the angle of the trailer shifting and so its center of gravity being ever so slightly closer to the other side, but it's no different than parking on slightly sloping ground...or walking from one side to the other in the trailer.
Cummins12V98
on the road
Posted: 06/07/19 09:38am Link  |  Quote  |  Print  |  Notify Moderator
People will say this will cause damage to the tire on the TrailerAid Plus. If your tires are harmed from this they will never last on the road since load is often moved fully from both tires to one.
This device is a much safer way to change out a bad tire or simply do maintenance.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
phil-t
Ogdensburg, NY
Posted: 06/07/19 11:33am Link  |  Quote  |  Print  |  Notify Moderator
What makes you think they are experts? If your tires are old, look at the DOT code, like 8 years; I would consider replacing them all.
Going down the road, with humps and bumps and turns, you will transfer more load to tires then jacking ever will.
2010 Winnebago Vista 32k on a 2009 Ford F53 22k chassis
monkey44
Cape Cod, MA and Central Fla
Posted: 06/07/19 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Love it, why did I think of that last time ... [emoticon] [emoticon] [emoticon]
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
 > Tire question?
