RV.Net Open Roads Forum: Travel Trailers: 6 volt battery question
 > 6 volt battery question
Raptorx9
Michigan
Posted: 06/07/19 07:44am Link  |  Quote  |  Print  |  Notify Moderator
I have searched the archives and I'm sure I'm just missing it, but what is involved in switching from a 12v battery to 2 6v in series? Do I need any special equipment? Any recommendations on amp hours? Brands?
Thanks!
PNW_Steve
Pacific Northwet & cold
Posted: 06/07/19 07:57am Link  |  Quote  |  Print  |  Notify Moderator
It all depends on what your power needs and space available for batteries.
I put two GC-2's in my TT. They are 6v 215a/h and "true" deep cycle batteries.
They are pretty much the best value in FLA. Costco and Sam's Club sell them for under $100.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
ktmrfs
Portland, Oregon
Posted: 06/07/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Sams or Costco GC2's seem to be the best value around. Way less cost than Trojan's and friends that have used them are getting many years of life out of them. I get 10 years or so out of a pair of Trojans, so we shall see how the Costco compares over time, but at less than 1/2 the price of a Trojan they so far seem to be a good choice, especially of your not a months/year dry camper.
2011 Keystone Outback 295RE
2oldman
New Mexico
Posted: 06/07/19 09:21am Link  |  Quote  |  Print  |  Notify Moderator
It's just a 12v battery in two pieces. Get AGM. Lots less maintenance.
Boon Docker
Posted: 06/07/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
No special equip needed. My Napa brand 230ah flooded GC2 batteries are into their 8th year of boondocking and are still going strong.
RoyB
King George, VA
Posted: 06/07/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
I recently picked up 4EA 6VDC DURACELLs part number SLIGC110 215AH GC2 GOLF CART Batteries from our local BATTERIES PLUS store... These were being sold at 84.99 each and they took my dud 85AH 12VDC Interstate batteries for CORE FEE...
Google image
This is wired with two Paralleled groups of 2EA 6V Batteries in series... Using my BLUE SEA switching shown bellow I can select GP1, GP2, Both GPs and all off... With both groups selected I should be able to see 430Ah capacity..
Roy's drawing image
I will be using the DURACELL batteries verse the TROJAN batteries being shown here.
I am mounting these in a TORKLIFT 59-inch slide off lid diamond plate battery box. This box came with one 10WATT Solar panel on one end and I will add a second 10WATT Solar Panel on the other end. These will be used to give both battery groups a good trickle charge during hig sun day sitting on my trailer tongue area...
This 59-inch battery box will fit perfect inside the battery rails on my trailer tongue where my 12V Intersate Batteries were being used... The box will extend over both sides of the tongue area...
Been using my three 12VDC Interstates batteries since late 2008 and they lasted until around 2014/2015 and finally stopped holding a charge...
Roy's image
Trailer has been sitting for a few years and I am getting excited now getting back to some off-grid camping once again...
Roy Ken
gmckenzie
BC
Posted: 06/07/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
When hooking up 6V batteries, make sure you understand they connect differently than 12v.
With 2 12V, you connect + to + and - to -. Then + and - to the trailer.
With 2 6v, you connect - from one battery to + on the other battery. Then you hook the + and - from the trailer to the unused posts.
2015 GMC Sierra 4x4 CC SB Max Trailer
2010 Cougar 30RKS
SpeakEasy
Western New York
Posted: 06/07/19 10:39am Link  |  Quote  |  Print  |  Notify Moderator
You asked what you need.
You need a short, heavy-duty cable to connect the two GC-2 batteries the way others have described. I found a 15-inch (or so) 000 cable with the appropriate battery-connection tabs already made. I think I found it at Tractor Supply. It was much less expensive than having my local RV shop make one, which they would have been willing to do.
You need a way to encase the 2 batteries. I opted for two separate battery cases, each designed to hold one GC-2 battery. I was able to mount them on the space where I had previously had one 12V case.
I also wanted a way to lock them down to prevent theft. I made an aluminum locking strap that surrounds the entire 2-battery-box setup.
Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
CA Traveler
The Western States
Posted: 06/07/19 11:42am Link  |  Quote  |  Print  |  Notify Moderator
GC2s are about 1" taller so make sure you have the vertical space.
2014 Grand Cherokee Overland
Bob
Raptorx9
Michigan
Posted: 06/07/19 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone!! Very much appreciate all the good info!!
