RV.Net Open Roads Forum: Class A Motorhomes: Class A automatic leveling never works!
 > Class A automatic leveling never works!
viajante
Plumas Lake, CA, (near Yuba City) USA
Posted: 06/07/19 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2008 Itasca that we LOVE except for the leveling effort when we reach our destination. We've had mechanics look at the Power Gear leveling system many times but the issue continues!
Went to the RV leveler blocks many years ago and now find those are cracking and generally need replacing. I understand those that love wood as a leveler, but we've attempted to keep things as lightweight as possible, without sacrificing safety.
Does anyone have a suggestion? What brand of leveling blocks do you use?
We're just not going to give up on this gem of a motor home. On the other hand we don't want to go to concrete slab destinations either! Thanks!
Dave & Brenda
Shadow (Sheltie), and Zoe (Shih Tzu)Faithful Companions
2008 Itasca Sunrise 35L
way2roll
Wilmington NC
Posted: 06/07/19 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly what types of issues are you having? Do they not auto adjust, not work at all, get stuck, etc???
I have found that the automatic mode on any of the class A's we have had worked a little wonky. They simply do things and continually micro adjust to the point that it twists and groans and usually ends up with one wheel off the ground. Once I swore the windshield was going to pop out. The auto level simply does way more than it has to. In my experience - in all three class A's we've owned, that manual mode on the leveling jacks is the only way to go. I have a level app on my phone and adjust the jacks accordingly. Way more easier and I think it's overall better for the RV.
KISS method.
wildtoad
Blythewood, SC
Posted: 06/07/19 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
As above, define what is happening when you auto level. We’ve had to train the system as to what is level, and it helps. (We have a different system than you, for mine there is a procedure for “setting the null” which is techno babel for telling the system what is level) At the same time, I’ll say that IF the site is reasonably level to start with, we will press the auto level. Otherwise we will level it manually using the buttons on the controller. Even then sometimes we have to adjust the location of the MH on the site to get it the way we want it.
We don’t use leveling blocks, but do have some wood blocks that I’ll take with us if I know we will be parked on dirt or gravel. These are primarily for providing a good base, so just a single board per foot.
And we have had auto level crack a windshield so be aware.
Tom Wilds
Blythewood, SC
MrWizard
Traveling
Posted: 06/07/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
I use the push buttons to get it level
Rather use the buttons to level hydraulically
Than mess with blocks where not needed
If I need blocks, I put them under the leveling jacks
Not the tires
Radiate The Happy
1997 F53 Bounder 36s
SDcampowneroperator
South Dakota
Posted: 06/07/19 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Auto level systems do get out of calibration. Use your manual override, put down each jack until you feel it barely touch ground, then level with your right -left setting forside to side,
Then to your front-rear setting to level front to back.
Dont trust the auto bubble, check with a carpenters level or better yet a frying pan with a little bit of water, its a 4 way level. Move it to several places in the rig, you will be surprised, average what you see. Then if you can recalibrate the system.
chuckftboy
Fleming Island, Florida
Posted: 06/07/19 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I've owned 3 coaches with Powergear automatic levelors, never had an issue. Most of the time we look for level sites to begin with. a few times we ended up on sites that were pitched and used them manually, useally with wood blocks under the feet. Seems strange that an RV tech hasn't been able to find the issue and make repairs.
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
2chiefsRus
USA Somewhere
Posted: 06/07/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
we are the original owners of the coach in our signature. I used the automatic level function exactly twice in nearly 12 years and 97,000 miles. The automatic level raised the coach way too high. I have learned how to use the MANUAL level function per the instruction manual. Much easier and faster than waiting and watching the automatic function groan on and on while lifting at least one tire off the ground.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
dodge guy
Bartlett IL
Posted: 06/07/19 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
My auto level works great. It does lift a wheel or 2 off the ground when needed, but that’s what makes it level!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
gafidler
Texas/South Dakota
Posted: 06/08/19 05:11am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 Winnebago and had a tec. talk on the phone with the manufactor while adjusting the auto leverer .. works great ever since.. good luck on yours
haste maker
alabama
Posted: 06/08/19 06:56am Link  |  Quote  |  Print  |  Notify Moderator
I have 2007 Allergro that the leveling jacks quit working & the repair shop "reset" the system & now all works well
Retried Teamster
2007 Allergo
