RV.Net Open Roads Forum: Class A Motorhomes: Class A automatic leveling never works!
 > Class A automatic leveling never works!
dcbrewer
kentucky
Posted: 06/08/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
It shows in the book that came with ours how to reset the auto level, Done mine on our level garage floor. works good after that. but before would have to tweek a little after auto level. We have the electric level leggs.
dcbrewer
kentucky
Posted: 06/08/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
SDcampowneroperator wrote:
Auto level systems do get out of calibration. Use your manual override, put down each jack until you feel it barely touch ground, then level with your right -left setting forside to side,
Then to your front-rear setting to level front to back.
Dont trust the auto bubble, check with a carpenters level or better yet a frying pan with a little bit of water, its a 4 way level. Move it to several places in the rig, you will be surprised, average what you see. Then if you can recalibrate the system.
I level mine at the frig, and also check the doors.
viajante
Plumas Lake, CA, (near Yuba City) USA
Posted: 06/09/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Our problem is even on what appears to be level sites, the auto level goes till at least one wheel is off the ground. Will definitely try the manual, one jack at a time method. Thank you all for the feedback.
Dave & Brenda
Shadow (Sheltie), and Zoe (Shih Tzu)Faithful Companions
2008 Itasca Sunrise 35L
deprived
Earth
Posted: 06/11/19 10:11am Link  |  Quote  |  Print  |  Notify Moderator
viajante wrote:
What brand of leveling blocks do you use?
Since this was your original question, I'll answer it. I use LevelLynx. They're light and cheap and fairly durable and you can get them at any Walmart.
