RV.Net Open Roads Forum: Do I need to worry about this butyl?
 > Do I need to worry about this butyl?
thedavidzoo
Tucson, AZ
Posted: 06/08/19 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
We bought a Northstar camper in 2016. The manufacturer, Rex, uses butyl tape extensively. It has oozed out of cracks and around jack plates, etc. as expected. Only certain areas have actual caulk/silicone (ex. tops of windows, roof, penetrations, inside edge of nose trim and area under nose).
I recently reapplied some Dicor on a few screwheads on the roof where the caulk was wearing a little thin. Otherwise it all looks great. Today while looking at the outside corner trim on the nose, I noticed that chunks of very dirty butyl tape had flaked out leaving up to a 1/8" gap between the sidewall fiberglass and the plastic trim piece. I'm assuming there is plenty more butyl tape down in behind there, however, I don't like the idea of water getting into that horizontal groove and meeting my wood.
When we pulled out the rubber trim to expose the screw heads that hold the plastic corner trim in place, 2 of the screws had discoloration on the heads and were rusty all the way at their tips. These 2 screws are immediately in front of the first little weep hole in the rubber trim. So, since it is kind of a low point there, is the rust due to water getting behind the rubber "flashing" and wicking up the screws before the weep hole, or is water getting in the butyl rubber gaps from above?
The pics show a small gap in butyl and an area where I just temporarily squished in some excess butyl in the big gaps.
With monsoon season almost upon us, do I need to pull the whole corner trim and put on a fresh length of butyl tape? Do I clean up the area as best I can and run a non-sag bead of Dicor over the entire length? I'd ask Rex or Bill at TCW, but I can't wait 2 months for an answer [emoticon].
Thanks!
2014 Ram 3500 CrewCab Diesel DRW 4x4 4.10 Aisin, Torklift Fastguns, Upper Stableloads, Timbrens
2017 Northstar 12' STC
640W solar, 400Ah lithium LiFeMnPO4 batteries
sbryan@vtbryans.com
Vermont
Posted: 06/08/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
David, it might take Bill a month to get back to you but my experience with Rex is he is very responsive. I would post this question up on the Northstar FB page and tag Rex. I'll bet you get a reply within a week.
You guys doing any big trips this year? We are in Acadia with our Igloo. The truck and camper now have over 30,000 miles on them and still doing great.
Best to you and the family. I haven't seen any of your issues on my Igloo but I'll be keeping an eye on things.
Shawn Bryan
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
work2much
Jackson Ca
Posted: 06/08/19 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
The insert trim on the underside of the camper is a vulnerable spot to introduce water into the camper. The insert trim runs from the top of the cabover and caries water to the underside where it pools in the cap which is inverted. Water can then wick up into the camper through unsealed screws. That rust is proof that is what's happening. Fill the hole with caulk and reinstall the screws and caulk the heads. I would do this the entire length of the insert trim. It is not water tight so water will get in along the top of the cab making any unsealed screw a potential leak.
I just went through this.
I also added a weep on each under side to keep water draining away from the camper.
As far as your other butyl, I personally would cut back everything that isn't helping and get a better look. I seal those joints with caulking and would probably reseal those areas after scraping off all the excess butyl. You might consider calling Northstar and asking what they would use to top that joint.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2018 Jeep Wrangler Unlimited toad.
Kayteg1
California > Nevada
Posted: 06/08/19 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Lot of butyl is good thing.
I think PO of my Lance redid all the trim and when I bought it, the butyl was creating "drops" coming out. When it look ugly and I start scraping that with my nails, the 18 yo camper has no dryrot beside couple of spots where butyl could not be used.
I tried several caulks, including high-priced marine grade and they turn yellow and either crack, of peel of easy, letting water to get under unnoticeable.
SidecarFlip
SE Michigan
Posted: 06/08/19 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
Been my experience that rusty screws are indicative of water intrusion from somewhere.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
jimh425
Western MT
Posted: 06/08/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
I’d ask Northstar since it’s not very old.
thedavidzoo
Tucson, AZ
Posted: 06/08/19 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I shot Northstar a note. We'll see what he says.
