RV.Net Open Roads Forum: blocks for leveling under jacks and tires
 > blocks for leveling under jacks and tires
MrWizard
Traveling
Posted: 06/08/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
you need one for each jack, AKA (4)
Radiate The Happy
1997 F53 Bounder 36s
Janss
Sedona, AZ
Posted: 06/08/19 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
I use yellow legos under my jacks. If on quite slanted site, I might put 3 under the left side jacks and one under the right side jacks...for example. I've never had a problem with breakage. For tires that may come off the ground, I carry two large pieces of wood that are long enough and wide enough for the left and right rear dual tires to be fully on the wood. Of course, I can use the wood for the front tires too.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
SidecarFlip
SE Michigan
Posted: 06/09/19 04:55am Link  |  Quote  |  Print  |  Notify Moderator
I use cut to the length of a side compartment, PT deck boards. I carry 12-15 in the side compartment, plenty to level with and cost was basically nothing, left over from a deck a contractor built for me.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
IB853347201
Eastern Ontario
Posted: 06/09/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
We carry 8 pieces of pressure treated 2 X 10 all in 1 foot lengths.
Generally this is sufficient to address any really unlevel sites.
We only put blocks under jacks that need additional length to level.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
fred42
Charlotte, NC, USA
Posted: 06/09/19 08:32am Link  |  Quote  |  Print  |  Notify Moderator
I have a 20 GVWR gas class A with the Atwood Levellegs system. I made some pads out of wood but when I went to the very few parks I go to I saw most of the class A's, even diesels, not using pads. I have not used them yet.
Am I to understand from this discussion that they are not only for soft ground but also to slightly decrease the jack travel and avoid extending fully?
2007 Tiffin Allegro 28DA
johnhicks
Wandering below the Gnat Line
Posted: 06/09/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
https://www.interstateplastics.com/Light-Duty-Rv-Jack-Pad-Accessories-MACH19MMx12x12OUTRIGGERPAD.php?&sku=details&sku=MACH19MMx12x12OUTRIGGERPAD&vid=&priceit.x=20&priceit.y=14
When you park on blacktop you'll need something to avoid punching a hole in it.
-jbh-
Seattle Steve
Tucson
Posted: 06/09/19 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I love my SnapPads. They stay permanently on the jacks so I never have to do anything except put the leveling jacks down.
Gjac
Milford, CT
Posted: 06/09/19 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
I just made my own from 1 in thk nylon sheets from old bathroom dividers that the YMCA was throwing away. They were 4'x8' shts so I made several for other RV's. I drilled a hole in the corner and painted the hole red so I could remove it with my awning rod. I only use them when the ground is soft or wet.
TechWriter
On The Road
Posted: 06/09/19 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
wannavolunteerFT wrote:
I do have four plastic jack pads.. but they are very thin and warp easily.
If you're talking about those orange/yellow things with cookie cutter bottoms, then throw them away. If they don't break, then they will probably piss off campground owners when you damage their asphalt.
One of the purposes of having jack pads is being able to move them. For example, at some sites we've had to double up the jack pads at the front or back to get level.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
Seattle Steve
Tucson
Posted: 06/09/19 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
My jacks move independently and automatically adjust for unlevel ground. They work great for me.
