RV.Net Open Roads Forum: blocks for leveling under jacks and tires
 > blocks for leveling under jacks and tires
wannavolunteerFT
South Georgia
Posted: 06/08/19 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
I've been RVing a long while and primarily used "LEGOS" for under stabilizers in TT. Now have 38ft Class A weighing about 24K lbs and am unsure what to use under auto-leveling jack pads and under tires if they are leaving ground. Are the "LEGOS" strong enough? They are almost the same size as the jack pads (I do have large plastic landing pads for when on dirt or asphalt).
What are recommended for under jacks to keep them from having to extend so far? If wood, what size boards? I prefer lighter weight or something that doesn't collect moisture and bugs so easily. I am trying to make a decision between weight and convenience and cost. They will have to be stored in the bins of the MH or inside toad car, as I do not have a truck or open storage for wet, nasty boards..
2015 FR Georgetown 378TS
rk911
Wheaton IL
Posted: 06/08/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
I used several layers of playwood nailed and glued together to form a block 1.5" thick. I have four of those. I also carry four other 3/4" boards to adjust as needed but I rarely need those.
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
TechWriter
On The Road
Posted: 06/08/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
We full time and can't rely on cobbling together wood pads, so we bought these RoadWarrior Jack Pads.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
T18skyguy
Eugene, OR
Posted: 06/08/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
I use square blocks cut from a 4x6, and more blocks from 2x6 stock and even some squares of 1 by material. My jacks don't need to deploy much. It's not the lightest, but not too bad either.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS. Wife and daughter. Three cats which we must obey.
CA Traveler
The Western States
Posted: 06/08/19 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Plywood blocks 1' sq, several pieces glued and screwed for 2" thick. Cut off one corner, install eyelet and rope loop.
2014 Grand Cherokee Overland
Bob
MrWizard
Traveling
Posted: 06/08/19 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
under the jacks, is wood or some black plastic jack pads the previous owner left in the rv for me
i use the orange blocks only for the wheels
i damage a couple of them putting them under the jacks
Radiate The Happy
1997 F53 Bounder 36s
Bumpyroad
Virginia
Posted: 06/08/19 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
my legos were not wide enough to support the sidewalls of the tires on my class A.
they would work on a TT however.
bumpy
rk911
Wheaton IL
Posted: 06/08/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
i just drilled a hole in one corner and looped some nylon cord through it
C20
Shawnee KS
Posted: 06/08/19 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I got some plywood called fin form (sp?) from united rentals. We used it in the fire services for shoring up trenches. Extremely strong. I get a sheet that had a piece cut out of it and cut some pads. Been using them for 10 years now.
08 Itasca 40 FD
02 Jeep Liberty
16 HD CVO Street glide
2015 Challenger Hellcat
2016 Ram Eco Diesel
wannavolunteerFT
South Georgia
Posted: 06/08/19 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
that is actually what I was wondering, as I will be fulltiming. Previously I have been lucky enough to be in fairly level sites, so haven't had to stack wood pads.. So are these things you recommend really $25 each? How many would you recommend? I do have four plastic jack pads.. but they are very thin and warp easily.
