RV.Net Open Roads Forum: Tech Issues: Apollo by Toastmaster Microwave oven appears dead
 > Apollo by Toastmaster Microwave oven appears dead
kmb1966
Lake Charles
Posted: 06/08/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Toastmaster by Apollo Microwave oven (Over the Range style) and was using it without an issue when suddenly while opening the door, the light goes out, panel goes dark and microwave breaker tripped. Reset the breaker and the outlet comes back on, but the microwave is completely dead. no lights, no fan, no nothing.
Problem is this is an odd size microwave in a cabinet (22") and I'm not sure if it can be replaced very easily.
Are these units generally repairable? I realize it is cheaper to replace than repair but if you can't find a replacement due to the size, I am wondering if they can be repaired. Maybe just a fuse? but something caused it to trip the breaker, so I'm assuming it needs to be repaired.
* This post was last edited 06/09/19 07:48am by kmb1966 *   View edit history
Bobbo
Wherever I park
Posted: 06/08/19 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Over the years, there have been LOTS of reports exactly like yours. Apparently, the Apollo Halftime Oven is known for that. The general consensus is to buy a quality microwave and replace it.
We were lucky, the Winnebago we bought in 2007 had one. When we sold the RV in 2017, it was still going strong. Apparently we were the exception.
Google the Apollo Halftime Oven (not just this forum) and read the reviews.
Bobbo, Linda and the furry kid (45 pound rescue)
road-runner
Oregon
Posted: 06/08/19 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Mine failed but didn't blow the breaker. The problem turned out to be cracked solder joints where a small transformer is soldered to the main board. So I was lucky to have an easy repair. Removing and reinstalling the oven from its hanging top mount, after removing some nailed-in cabinetry, was the worst part of the job. Getting the case off was the 2nd worst part.
2009 Fleetwood Icon
kmb1966
Lake Charles
Posted: 06/08/19 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is a toastmaster by apollo model ad-13b
I don't know about Apollo Halftime. That's not what I have.
SidecarFlip
SE Michigan
Posted: 06/09/19 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Micro's are cheap, buy a new one and if it don't fit, buy some trim and make it fit.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
pauldub
North of Seattle
Posted: 06/09/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
These are built-in compatible.
kmb1966
Lake Charles
Posted: 06/09/19 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Not sure if I can do that because this is an "over the range" microwave. No room to go wider and can't find a 22" OTR Microwave anywhere. I can find 22" non-over the range, but I am not sure if I can put a non-otr unit over the cooktop. I would think the cooktop would need a vent,etc. [emoticon]
kmb1966
Lake Charles
Posted: 06/09/19 07:44am Link  |  Quote  |  Print  |  Notify Moderator
These would work except none of them appear to be Over the Range style. The hole is over the range and I am not sure if a non-OTR style can work there. Doesn't the range need a vent and heat protection? [emoticon]
DownTheAvenue
Sunny South
Posted: 06/09/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
DO NOT try to repair the microwave yourself. Inside there are items that can deliver a lethal jolt of electricity even if not plugged in.
MrWizard
Traveling
Posted: 06/09/19 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
OOPS.. answering the wrong question
deleting
* This post was edited 06/09/19 03:18pm by MrWizard *
Radiate The Happy
1997 F53 Bounder 36s
