RV.Net Open Roads Forum: Fifth-Wheels: new water pump - now water filling tank??
 > new water pump - now water filling tank??
Brad NSW
California
Posted: 06/08/19 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
Just put in a shurflow 4800. Now when I took up to city water, my tank fills and overflows and I get no water pressure.
The pump works great, super quiet, and great flow when I'm not on city water. Yes, the valve is turned to normal and not tank fill.
Any ideas?
USN Ret. 03Ram3500, 5.9CTD, 5spd, SRW, ATS filter, S&B Intake, IssPro (Pyro, Boost, Fuel, Trans & R Dif) SMARTY SR, Prodigy Controller, AirDog 100. 09Montana 3665RE 5er, 6 TST Tire monitors. Pakbrake Ex brake & airbags, 12' Baltik inflatable w/3.3HP OBM
Old-Biscuit
Verde Valley
Posted: 06/09/19 12:33am Link  |  Quote  |  Print  |  Notify Moderator
You stated.....
On city water but no pressure inside...fresh water tank overflowing
Check your valving......something is not set up correctly
* This post was edited 06/09/19 12:52am by Old-Biscuit *
12th Man Fan
Flower Mound , Texas
Posted: 06/09/19 06:18am Link  |  Quote  |  Print  |  Notify Moderator
If you have all of the fill valves in the correct position then you have a bad check valve in the pump. Some debris may be the cause.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
pasusan
Northernmost PA
Posted: 06/09/19 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Call Shurflo - we also got a bad pump and they sent me a new one that worked.
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben
2004 Roadtrek 170 for quick getaways
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub for longer trips
Trip Pics
laknox
Arizona
Posted: 06/10/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
x2 on the check valve on the pump.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
Planning
Idaho
Posted: 06/10/19 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Any ideas?
More than likely the checkvalve in the pump is bad. This is very common and a repetitive issue with Shurflo pumps.
Install this on the discharge hose coming out of the pump:
https://www.amazon.com/gp/product/B000EDUTN6/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
This model is good quality with metal (not plastic) internals.
You might need adapters to place this in line with your hose; the Shurflo pump connections are specific to those fittings so just cutting the hose and "barbing these in is easiest.
adapters like these: https://www.amazon.com/dp/B000BPECSK/?coliid=I1FX1IZI2CSVX1&colid=32BP8LZDSEKI7&psc=0&ref_=lv_ov_lig_dp_it
2016 AF 29-5K; 2016 F350 6.7, 4x4, CCLB DRW
Brad NSW
California
Posted: 06/11/19 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks PLANNING. Parts on order. Looks like an easy fix and bad check valve makes sense.
laknox
Arizona
Posted: 06/12/19 09:39am Link  |  Quote  |  Print  |  Notify Moderator
If you've got a NEW pump that's backflowing, why wouldn't you warrant it for another one, that works correctly, instead of bandaiding the defective one? [emoticon]
Lyle
Planning
Idaho
Posted: 06/12/19 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Lyle
Because the Shurflo check valve is an historical single-point-of-failure, and a dedicated check valve is a more positive remedy not requiring repetitive repair.
laknox
Arizona
Posted: 06/12/19 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Planning wrote:
Lyle
No matter. A new, and properly functioning pump is what was paid for and what should be delivered. If it fails later, then install the other valve.
Lyle
