RV.Net Open Roads Forum: Lithium batteries high for Stepwell, will they start genny?
 > Lithium batteries high for Stepwell, will they start genny?
DAS26miles
SoCal
Posted: 06/09/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking of replacing my original group 27 batteries that are in the step well compartment. The height clearance is 10" deep and the originals are 8 1/2 " high. The Lithium batteries that I'm considering are 9" and 9 1/2" high. That doesn't leave much clearnace for the cables on top. Being so close to the top has me wondering if hitting a bump in the road could cause the batteries to hit the metal step lid and shorting. Also, I read that Lithium batteries are not designed to start motors of any kind. What about the generator? My 4K Onan seams to peak just under 180 amp at start up. The Lithium specs say the 100 amp batteries can go to 200 amps for a few seconds, Any feed back?
Sam Spade
North Central Florida
Posted: 06/09/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I think you will be MUCH better off getting AGM batteries.
They will be a bit more expensive than conventional but nothing like Lithium.
The existing charging equipment will work good with AGMs too.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
77rollalong
Brighton Ontario
Posted: 06/09/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
our genset starts off the coach battery, not the house battery. You may able to modify the battery box to drop it down lower to clear the top
D.E.Bishop
Eagle Rock, CA
Posted: 06/09/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
I would install battery hold downs in either case. The batteries should not be free to move about.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
time2roll
Posted: 06/09/19 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Yes they will start the generator. Get terminal covers if the clearance is tight. And yes all batteries should be held down.
Terminal covers
675w Solar pictures back up
2oldman
New Mexico
Posted: 06/09/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Can you lay the batteries on their sides? Li batteries should start anything.. huge current capacities.
DAS26miles
SoCal
Posted: 06/09/19 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
My existing tie down strap should work. But has any one out there actually installed Lithium in their step compartment? What's the advatage of AGM's besides price? They don't discharge at a constant voltage or charge as fast as Lithium.
Seattle Steve
Tucson
Posted: 06/09/19 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a video giving estimated cost comparisons between the 3 types of batteries.
RV Battery Comparison
DAS26miles
SoCal
Posted: 06/09/19 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I'm more sold on the Lithium. It's a PITA to check the water level in the step compaartment with all the cables running on top of the batteries.
Chris Bryant
Arden, North Carolina
Posted: 06/10/19 05:37am Link  |  Quote  |  Print  |  Notify Moderator
Are you getting batteries with the Battery Management System built in? Lithium are tops, but you don’t really just drop them in usually. I really would look at AGM.
-- Chris Bryant
