RV.Net Open Roads Forum: Lithium batteries high for Stepwell, will they start genny?
 > Lithium batteries high for Stepwell, will they start genny?
DAS26miles
SoCal
Posted: 06/10/19 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Chris Bryant wrote:
Are you getting batteries with the Battery Management System built in? Lithium are tops, but you don’t really just drop them in usually. I really would look at AGM.
Yes, they will have the management built in and I have a Lithium mode solar controller. Battleborn says my existing Progressive Dynamics converter charger will work fine charging the Lithiums but I will need to hit the charge wizard and have it go into bulk at 14.4 volts. I will get Progressive's dedicated Lithium converter charger I see everything is working. But first I have to make sure it will fit and start the generator.
2oldman
New Mexico
Posted: 06/10/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
I don't know where you got the idea it won't start a motor.
DAS26miles
SoCal
Posted: 06/10/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Read it on the internet some where.
Sam Spade
North Central Florida
Posted: 06/10/19 09:36am Link  |  Quote  |  Print  |  Notify Moderator
DAS26miles wrote:
They don't discharge at a constant voltage or charge as fast as Lithium.
Neither of those "advantages" really do you any good in a camping situation.....usually. The "standard" charging equipment usually won't take full advantage of the different charging characteristics.
In my opinion, a waste of money for most people.
But it's your money; do whatever makes you happy.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Sam Spade
Posted: 06/10/19 09:37am Link  |  Quote  |  Print  |  Notify Moderator
DAS26miles wrote:
It's a PITA to check the water level in the step compaartment with all the cables running on top of the batteries.
Which is why AGMs are a good choice. No "water level" to check with them either.
But it is rapidly beginning to look like you already have your mind made up and cost is not an obstacle....whether it should be or not....so good luck.
Don't confuse me with facts, my mind is made up.
2oldman
New Mexico
Posted: 06/10/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
That explains a lot.
DAS26miles
SoCal
Posted: 06/10/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
I know, everyone knows what you read on the internet is true! Thant's why I posted this topic, I didn't believe it.
