RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel hitch
 > 5th wheel hitch
sljohnson1938
Mount Airy, NC - USA
Posted: 06/09/19 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
ok - I currently do not have a 5th wheel. we sold the last one several years ago and later I sold the reese 15k pro series hitch and rails.
The 5th wheel was a Wildcat, do not remember the length, but probably in the mid 20 ft range. Had a rear kitchen which the wife really liked.
we are thinking of returning to a 5th wheel. small one - mid 20 ft range. about same size as the one we had before. there is only the 2 of us, so we do not need a bigger one.
question is - I have been looking at the same Reese 15K pro series hitch. But I have also saw a similar Curtis series hitch. The difference is about $100 less for the Curtis.
Any comments?
1999 Dodge 3500 CTD dually
Ham radio - WU4S
Cummins12V98
on the road
Posted: 06/09/19 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Both Chinese Made. Look at Pullrite, Andersen, B&W along with the few other USMade hitches.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
agesilaus
North Florida
Posted: 06/09/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto on that, tho I am still not a fan of the Anderson. But avoid Reese.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
twodownzero
NM
Posted: 06/09/19 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
For a tiny 5th wheel, any hitch will be fine. I use a pullrite.
amxpress
Clayton, NC
Posted: 06/09/19 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Reese 15K Pro that I had to replace after 5 years, but is was covered by a 10 year warranty. If I had to do over again I would have requested a B&W be installed when I purchased my first fiver. Live and learn.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L is out of state, out of touch, and out of her mind
Cummins12V98
on the road
Posted: 06/09/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
I am not either but for a lighter weight RV they would be fine.
Cummins12V98
on the road
Posted: 06/09/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
If you appreciate quality there is nothing close in a non air ride hitch.
ralphnjoann
Colorado
Posted: 06/09/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 24' Mobile Scout (Sunnybrook) with a dry weight of 5429 lbs. We tow with a rail mount Andersen hitch. We are both in our late 70s with our health not so good, so the light weight, 43 lbs, was the reason we chose the Andersen. We've been very happy with it.
WTP-GC
FL
Posted: 06/10/19 04:43am Link  |  Quote  |  Print  |  Notify Moderator
sljohnson1938 wrote:
Any comments?
If comments are what you want, you've come to the right place!
I'll stop short of saying anything about any hitch in particular. But as I've gotten older (and theoretically wiser), I've learned that a few hundred dollars savings on a product of this nature should have little impact on my decision making. It's like the other thread going about leveling blocks...spend $25K on a RV but try to save $5 or $10 on an accessory? Spend the money now instead of getting a cheaper product that you'll end up being unhappy with and/or replacing down the road.
2017 Chevrolet 2500 Duramax Crew Cab Z71
2014 RAM 3500 DRW 4x4 6.7 Cummins w/ Aisin, Flatbed
2018 Grand Design Reflection 150 Series 290BH w/ B & W Companion (T/O Ball)
Old Rig:
2005 Wildcat 29BHBP w/ Andersen UH (Aluminum, lowered version for flatbed)
SBGTF
Dave H M
IL
Posted: 06/10/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
so what is wrong with a Reese 15K?.. I been running one with the 10K fifth wheel for eons.
 > 5th wheel hitch
