RV.Net Open Roads Forum: Tech Issues: Stove Burner Issue
 > Stove Burner Issue
Art Davis
Shady Cove, Oregon
Posted: 06/09/19 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
My wife complains that our Magic Chef burners are full on or full off, no adjustment in between! Are there any practical solutions short of replacing the stove?
Do the best you can with what you have to work with.
Arctic Fox 22GQ
Dodge Ram 1500 Crew Cab
ken56
Tennessee
Posted: 06/09/19 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Portable induction appliance. NuWave or likewise...but you need 110 volt so that means shore power is required.
opnspaces
San Diego Ca
Posted: 06/09/19 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Are they propane burners or some kind of electric burner? Have you checked to see if the only full on or full off is actually the case? How far do the knobs turn between full and low? If they are say 3/4 turn, what happens if you light a burner on full, and then turn the knob half of it's travel? Does the flame seem the same height as full? Maybe the stove is slow to respond, does the flame drop in size after a minute or two when you turn the knob?
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
jkwilson
Indiana
Posted: 06/09/19 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
I’d suggest checking the stove gas pressure. Really should be an annual maintenance check.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
DrewE
Vermont
Posted: 06/09/19 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Many (well, at least some) RV propane stoves don't have "official" settings between high and off for some of the burners. That doesn't mean you can't turn the control knob halfway between off and high and get a lower setting, though it make take some care to adjust it finely in that zone. The control is just a valve, after all.
ROBERTSUNRUS
Salem, Oregon
Posted: 06/09/19 11:57pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, on my three burner stove top, the front burner is the only one that is adjustable. The back two burners are basically on or off, but you can adjust them by barely turning the knob. As mentioned in the previous post.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
pauldub
North of Seattle
Posted: 06/10/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Look at the flame and turn the knob. It's not a linear adjustment, but it is adjustable. At least that's how it is with our Magic Chef range.
GordonThree
Northern Michigan
Posted: 06/10/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Same problem on my Suburban stove, it does adjust but it's super sensitive for the low range. 2/3 of the travel is full power and the last bit is medium and low.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
maddog348
Bakersfield,CA
Posted: 06/10/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Our stove top 3 burner ~ 2off/on ~~ 1 adjustable. Always have been. What does your manual say.
JM2¢ ~~ YMMV
2oldman
New Mexico
Posted: 06/10/19 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
That's ridiculous. They should all be adjustable.
