RV.Net Open Roads Forum: Fifth-Wheels: Fifth wheel brakes
 > Fifth wheel brakes
Rwake901
Central, Illinois
Posted: 06/10/19 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
I cannot lock up the brakes on our 15,000 lb. triple axle toyhauler, never have been able to. It seems to stop well enough so I don't worry about it.
This is kind of where I’m at. Yes they will stop me ok but I would have thought with the brake unit turned up all the way it would lock up the brakes. If this is normal then I won’t worry about it. Thanks
Terryallan
Foothills NC
Posted: 06/10/19 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
stickdog wrote:
I was told if your brakes are adjusted properly you should set the gain at 50% in a safe area drive to 20mph and stomp on the pedal. If your trailer brakes lock reduce gain, if not increase gain and repeat and continue to increase the gain till they lock at 20mph. You then want to back off to the previous gain where they didn't lock at 20mph. As the brakes wear you will need to either adjust the gain or the brakes.
You don't really do that do you?. The correct way is to pull the brake LEVER on the controler. Not stomp the pedal.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Edd505
Elephant Butte, NM
Posted: 06/10/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
when were the brakes adjusted last? Mine don't lock but you definitely know they are on. You don't say what the TV is, built in controller or after market?
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
buc1980
houston tx
Posted: 06/11/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
On the heavy FW will be hard if you don't have disk breaks.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
