RV.Net Open Roads Forum: Class A Motorhomes: Warning Light on 2002 Monaco Diplomat
 > Warning Light on 2002 Monaco Diplomat
devildog1971
Rome
Posted: 06/10/19 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
I checked the manual and it states to stop and check all fluids. the coolant is ok , the oil level is ok, the oil pressure is at 60 at idle the coolant is 190 degrees. the transmission shifts alright I need to locate the dip stick for the transmission. I think it is a malfunctioning sensor. I drove it home 600 miles sometimes after a stop it would come on sometimes it did not light up nothing seems out of the ordinary? except the light is on the air pressure stays around 120 pounds and does not leak down when the engine is off HELP
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2013 Harley Davidson Ultra Classic
opnspaces
San Diego Ca
Posted: 06/10/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Does the manual state the name of the light? Is is a malfunction indicator light or check engine light? If it's not named in the guide can you describe the light or take a picture and post it?
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Tom/Barb
Oak Harbor, Wa
Posted: 06/10/19 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Have you checked the differential pressure indicator on the air filter ?
My Roadtex computer threw a transmission over temp code on our trip back from Texas. Next fuel stop I checked the fluid level and it was way low. added 4 Its fluid, reset the fault codes in the computer, has been OK since.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
faucet1
Posted: 06/10/19 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
After filling up with fuel one night and, upon starting engine, a stop engine light came on immediately. Checked around coach and then proceeded to campground nearby. The next morning upon start-up the light had disappeared. I was a little hesitant to get on the road to my destination, and proceeded with some caution. Didn't have any further concerns. Never have had that again. Good luck with yours.
2002 Monaco Diplomat 40 PST Triple Slide
Toad-88 Ford Mustang GT-Stick
David and Jean
winniman
muskoka
Posted: 06/10/19 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
What transmission do you have. If you have the 3000 or better, you can check the transmission fluid with the shift selector pad. The manual says it is more accurate than the dipstick. The transmission has to be warmed up to do it. Just hold the up and down buttons at the same time. It will give a code indicating the level. The exact instructions will be in the allison manual that came with the rv. If you have the 2500 series or less, this feature is not available.
Executive
Posted: 06/11/19 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Please post what engine tranny combo you have. Also, let us know what you mean by a warning light. On mine the red light comes on accompanied by a loud 'ding'. As it flashes, it says why. i.e. check engine, fluids, water in fuel etc. If it's just a warning light with no indicator I can see where that would be irritating as well as disconcerting....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
devildog1971
Rome
Posted: 06/12/19 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
it is the allison transmission and cummins diesel
devildog1971
Rome
Posted: 06/12/19 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
it is a "warning" light
2chiefsRus
USA Somewhere
Posted: 06/13/19 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Which allison and which cummins?
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
slickest1
canada
Posted: 06/14/19 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
On my previous coach I had that same light that says warning come on a couple times. I had the codes read and it turned out to be my Caps Fuel pump was having problems. Yours may be different but I think that warning light warns of low levels of fluids or a code being stored.
1998 Holiday Rambler Imperial 40 ft.
Dennis and Marcie and Pup the Jack Russell
