RV.Net Open Roads Forum: Tech Issues: suburban water heater flow stopage
 > suburban water heater flow stopage
prstlk
Post Falls ID
Posted: 06/10/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
07 36 ft 5th wheel with a suburban AC/LP hot water heater.
Just today while running hot water for dishes and the flow just stopped not only at the sink but bathroom sink shower and outdoor shower. I had cleaned the outdoor water hookup area and thought I may bumped the bypass valve. Checks out okay. Started working a again and while I was rinsing the dishes it quit again I heard a thunk from the area behind the pantry where the heater lives. I checked the reset buttons on the heater nothing there either,
Any ideas as what would interrupt the hot water flow but not the cold?
Thanks to all in advance
Jim
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
dougrainer
Carrolton, Texas
Posted: 06/10/19 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
The Hot water exit fitting probably has a check valve and that valve may have mineral deposits. How often do you replace the Anode rod? Doug
Roger10378
Goodrich, MI.
Posted: 06/10/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Even more likely is that the check valve has failed. Most are cheap plastic and fall apart. If you can find a brass check valve it will be worth the extra cost.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
prstlk
Post Falls ID
Posted: 06/10/19 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
Doug,
Can you enlighten me on what the exit fitting looks like? The anode was checked in April and it was fine.
DFord
Near St Louis, MO
Posted: 06/10/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
At the hot water outlet of your water heater, I'll bet there's a check valve like this one:
It's pretty small and not very conspicuous but if you've got a single handle water heater bypass, you've got one of these valves. The disk that prevents the backflow of water into the heater is plastic and held in place with a small rivet. That rivet pulls through the plastic and plugs up the outlet to the heater.
Be careful selecting a replacement. I was able to find one with a brass disk instead of plastic. It was the same brand but I'm not sure if it had the same part number.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Old-Biscuit
Verde Valley
Posted: 06/10/19 11:49pm Link  |  Quote  |  Print  |  Notify Moderator
Top fitting is HOT out
Fitting screwed into the HOT Out will be the check valve
It is clogging up with scale/crud/minerals
prstlk
Post Falls ID
Posted: 06/11/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all who answered. It was indeed the check valve at the top of the water heater. $10.00 part.
I would recommend everyone have a 1" deep well socket on hand in case you need to remove the old one.
Make sure that you open the pressure relief valve on the water heater so it can fill with water after the replacement.
Also recommend that you study up on being a contortionist because you have to crawl up into the belly of the unit to be able to get to the check valve (at least that's what I had to do).
Old-Biscuit
Verde Valley
Posted: 06/11/19 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Glad you got it working!
No need to open T&P Relief Valve when refilling.
Turn on water supply and then open nearest faucet hotside.
This will allow cold water to flow into WH Tank, displace the air in system AND establish the 'air pocket' at top of tank,
Air pocket helps control pressure increases when heating water as it will SWELL when heated so w/o air pocket pressure can increase and cause the T&P Relief Valve to 'weep'
Opening T&P can cause air pocket to be expelled vs being established
Bobbo
Wherever I park
Posted: 06/12/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
If you depressurize the water system and open the pressure relief valve, it will also re-establish the air pocket.
Bobbo, Linda and the furry kid (45 pound rescue)
Old-Biscuit
Verde Valley
Posted: 06/12/19 10:42am Link  |  Quote  |  Print  |  Notify Moderator
YES.........
That is How you can re-establish a lost air pocket
Opening T&P with NO pressure/flow
Opening it WITH water turned on can displace the air pocket because the water will churn inside the WH Tank and carry the air out thru T&P vs flowing naturally thru hot out dip tube to an open faucet
