RV.Net Open Roads Forum: Looking for motorhome to travel to Alaska suggestions?
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Looking for motorhome to travel to Alaska suggestions?
Iamfreeatlast
Canton
Posted: 06/10/19 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
I am getting very close to buying my first and only motorhome. I am planning on full timing in it and go to Canada and then Alaska. Should I get one with no slide outs to help maintain inside temperature?
Tom/Barb
Oak Harbor, Wa
Posted: 06/10/19 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Do you plan on being in Alaska during the winter?
I really wouldn't advise that.
there really isn't a coach built with the insulation required for -40 degree temps.
we've done a couple nights in the 20s and our furness runs full time.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 06/10/19 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to assume you'll be traveling north in the summer months and not the middle of winter???
Get one with slides - be comfortable. But, you should get one you can use with the slides closed if need be. By that I mean you need to be able to use the kitchen, use the bathroom and use the bedroom without any problems. We leave our slides in more when it's very hot out for better cooling, but have left them in at night when it's cold.
The interior of Canada and Alaska can be very warm during the summer months. Make sure you get a MH with two good working 15K air conditioners and a good dash air conditioner.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
ppine
Northern Nevada
Posted: 06/10/19 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
Great place to spend the summer until Sept.
I knew a guy that bought a Sarenghetti MH with a Cummins diesel, but it had no glow plugs. Watch out for things like that.
A medium to smaller MH is easier to buy fuel for and easier to heat.
A diesel is worth considering if you are planning to travel 5,000 miles.
CA Traveler
The Western States
Posted: 06/11/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Good advice above. Summertime travel in Canada and Alaska is the same as the US.
2014 Grand Cherokee Overland
Bob
ppine
Northern Nevada
Posted: 06/11/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Alaska is the US.
The weather is much different than the Lower 48.
I almost froze to death in Alaska on August 31 at the top of Chilkoot Pass.
I worked in SE in 150 inches of rain and wore wool long underwear every day even in July.
The Interior gets warm in summer, but it starts snowing by Labor Day.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 06/11/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
A month ago you were looking to buy a 5er and now a MH. Without a budget and # of people we are just guessing at what you should buy. Heating and cooling is normally not a problem.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
Tom/Barb
Oak Harbor, Wa
Posted: 06/11/19 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
">jAAAOSwN2Zc92DC]This
is one of my favorites
As far as durability and being well built, It is near the top of the list.
the bear II
Torrance CA.
Posted: 06/11/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Look at www.rv-dreams.com they are currently travelling in Alaska with friends. Both have Class Cs with slideouts.
Also www.keepyourdaydream.com travelled through Alaska in a travel trailer with slideouts.
Iamfreeatlast
Canton
Posted: 06/11/19 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I am researching my numerous options to the tenth degree so that I don’t make a huge monetary mistake. I have been recovering from a severe fall and just now starting to walk again. Everything was put on hold. I will look at the various sites as mentioned and heed their advice. Thank you.
