RV.Net Open Roads Forum: Tech Issues: Extension on Battery post
 > Extension on Battery post
rickhise
home
Posted: 06/11/19 12:47am Link  |  Quote  |  Print  |  Notify Moderator
Battery post stud is too short. My bank of 6 - 6 volt are golf cart InterState batteries.
Has extra heavy terminal ends on heavy gauge wire. My only issue was the first positive stud on the first battery. The positive stud isn’t long enough.
My question is. How can I get one more terminal on a post that has
no room. If I fabricated a copper stip 1/2 inch wide 11/2 inch long
Drilled a hole in one end for the batt stud, drilled a 2nd hole in the
Other end with a locking nut to hold the terminals?
Is copper adequate for the best connection?
Any other ideas to try?
These bats came with just one threaded stud.
No battery post as typical on. a marine batt.
Sorry I was vague on the size wire and # of terminals
Tom_M
New Hope, MN
Posted: 06/11/19 04:15am Link  |  Quote  |  Print  |  Notify Moderator
Your solution will work fine. I use a piece of flattened copper tubing and drill holes in it.
Tom
2005 Born Free 24RB
Towing 2013 Smart Car
RoyB
King George, VA
Posted: 06/11/19 05:56am Link  |  Quote  |  Print  |  Notify Moderator
For me I like to only have ONE battery cable going to each of the two Battery terminals... Positive and Frame ground...
A good BLUE SEA Terminal strip from AMAZON is helpful for multiple connections...
Google image
The ones with the cover like shown here really are best to use for the POSITIVE side connections...
I would use a heavy gauge battery cable with ring terminals (AMAZON) as short as possible between your battery and the terminal strip...
Roy Ken
* This post was edited 06/11/19 06:04am by RoyB *
dougrainer
Carrolton, Texas
Posted: 06/11/19 07:15am Link  |  Quote  |  Print  |  Notify Moderator
battery terminal extender. EASY solution. Doug
https://www.iboats.com/shop/sierra-start........63sLh4gIVjoCfCh3X0gyLEAQYBSABEgKiuvD_BwE
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 06/11/19 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Connecting more than one lug to a battery post is asking for problems. Stud battery buss bars like shown above in this thread, reduce future issues dramatically. I do not use the word 'dramatically' lightly.
I even limit terminal stacking to (2) two per stud on a buss bar. OEM uses more than one per battery terminal but the cables enter the clamp lug and are crimped in the barrel of the lug.
I've run into countless wiring disasters where a customer has a pair of batteries and six or eight extraordinarily corroded wires and cables connected/stacked direct to the lead battery posts. I would loosen the nuts then tell the customer to get lots of boiling baking soda, go back to camp boil water, add the baking soda then soak the ends of the wire in the baking soda. It's a messy, frustrating, time eating job.
To pay me to do it was unwise. Expensive with a capital E. And the cost caused more arguments and bad feelings than any other I can recall.
If
"That's why I am asking YOU to do it".
If they balked and cursed at the cost of labor then it was 'Down The Road Dugan¨.
Matt_Colie
Southeast Michigan
Posted: 06/11/19 08:41am Link  |  Quote  |  Print  |  Notify Moderator
In about fifty years of doing boat electrics and all of the last ten before the depression ended the profit side of the work, I never put more than two lugs on a battery post. More than that and you are asking for trouble down the way. If you sit down with a paper and pencil and draw out the plan, you can get all of the jars connected and never have more than two connections on a post and also have the same number and length of jumpers in each string. This may sound stupid, but the balance of a multi-string bank can be upset by milliohms in one string.
If you need a sensor lead to the bank or other very low drain attachment, don't put in on the bank directly, attach it at the other end of the feeder cable where it will not be subject to the corrosion and include a fuse.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
rickhise
home
Posted: 06/11/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Matt. Will follow your advice
road-runner
Oregon
Posted: 06/11/19 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Trying to bring up this web page hangs my 52.5.2 ESR firefox browser. Haven't run into that for a long time.
2009 Fleetwood Icon
pigman1
Delaware
Posted: 06/11/19 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
Go to your local hardware store and get a 3 or 4" piece of soft copper 1/2" pipe. Pound it flat, drill 2 or 3 holes and use copper, brass or stainless bolts with lock or star washers for attaching lugs you need. Once flat, don't continue to pound as the copper will work harden and become brittle. I've used soft copper water pipe for DC bus bars for years and never had a problem.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
