RV.Net Open Roads Forum: Class A Motorhomes: Winegard RV-6004 TV antenna
 > Winegard RV-6004 TV antenna
Craig Ross
Jeff's RV Park
Posted: 06/11/19 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have a veteran friend whose antenna was destroyed by winds. I dont use my Winegard antenna and was wondering if I could disconnect from my trailer and just hook his coax straight from his TV into it , will that work. His trailer is an old one so it's not like mine
Sam Spade
North Central Florida
Posted: 06/11/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
There likely is a "pre-amp" involved in the original setup.
Might work OK, and might not.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Tom_M
New Hope, MN
Posted: 06/11/19 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
You can not come straight off the antenna into the TV. You will have to connect to the wall plate inside your RV. The antenna has an amplifier in the head that needs power that comes from the wall plate.
Tom
2005 Born Free 24RB
Towing 1978 VW Bug convertible
Minneapolis, MN
dougrainer
Carrolton, Texas
Posted: 06/11/19 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
If you friend had a Winegard Antenna and he has the Interior Booster wall plate, you can run a Coax from YOUR Batwing to the Cable on top his RV. Connect the coax wires together and he will use his booster to power your antenna, which will feed his TV. Doug
RLS7201
Posted: 06/11/19 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
NOT all Winegard bat wing antennas have amplifiers in them. A lot of trailers have the NON_amplifies antenna installed. You will get very poor reception when using an amplified antenna with out the power inserter (wall plate).
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
