RV.Net Open Roads Forum: Tech Issues: Electric Brake Issues - Weak Brakes
 > Electric Brake Issues - Weak Brakes
babock
Los Angeles, CA
Posted: 06/11/19 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
I don't buy the burnishing. I've never burnished brakes and haven't noticed a difference in stopping power. Even if burnishing has an effect, I don't think it will have the effect you're looking for.
Mine didn't stop worth a **** until I burnished them. Was night and day after I did the burnishing procedure.
I do agree with running home runs for every wheel back to the tongue. Way easier to diagnose an electrical issue since you can isolate it to one wheel/circuit.
BTW...they are never wired serially. I think you are confusing it with "daisy chaining". The magnets are still in parallel.
Lynnmor
Red Lion
Posted: 06/12/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
tsherv wrote:
I think I'm on to something: I tested the voltage of the blue wire coming from my brake controller while pushing the manual override. It measured 12 volts (which it should). When I tested the brake pin of the 7 pin connector, it only registered about 3 volts. I tested the blue wire right before it went into the 7 pin connector, and it measured 12 volts. I'm thinking maybe the 7 pin connector on my truck is bad?
Sounds like you found it. Do check the other pins as well so you know that you have a good ground while checking with a voltmeter. Even with a bad connection, it is surprising that the reading is that low with no load.
Usually you should replace all brakes on an axle so they have the same effect. Yes, burnishing does take time and with only one side new, there will be quite a difference possibly pulling the trailer to one side. Don't believe those that discount the effect of burnishing, in recent years brake friction material has changed causing the poor performance when new.
drsteve
Michigan
Posted: 06/12/19 11:01am Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking you're correct.
1991 Palomino Filly PUP
joshuajim
Mojave Desert
Posted: 06/12/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
When you installed the new brake, was the small shoe towards the front of the vehicle?
RVing since 1995.
time2roll
Posted: 06/12/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Wear on one side indicates you already had an issue of non functioning brakes. There is no wear when they don't function.
I recommend starting with a DC clamp-on ammeter at each wheel. Full manual braking you should see 3 amps at each wheel. If they are all low you have a central connection issue. If one is low you have a problem with that one wheel.
675w Solar pictures back up
