RV.Net Open Roads Forum: Tech Issues: Dometic stove
 > Dometic stove
cpaulsen
Oregon
Posted: 06/11/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
2018 Dometic 3 burner stove with glass cove and I have one burner that will not light with the piezo ignitor. Other 2 work great.
cpaulsen
fj12ryder
Platte City, MO
Posted: 06/11/19 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Does the ignitor actually work on that burner? Can you light the burner with a match? And whats a "glass cove"?
Howard and Peggy
"Don't Panic"
DrewE
Vermont
Posted: 06/11/19 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
I think a "glass cove" is a glass cover that has lost the r. (Maybe the r got stuck between the ignitor electrode and the burner?)
Seriously, I would take a good look at the ignitor electrode on the burner that doesn't light properly and make sure it looks right. I'd also look for a spark there by hitting the ignitor in the dark; presumably there is none. If the electrode looks like it's positioned properly, maybe you can find a wire to it that has fallen off or something by popping the "hood" of the stove--usually the top part can be swung up somehow for cleaning and maintenance.
If the burner won't light with a match, then the problem apparently isn't the ignitor but something in the valve or burner assembly, such as a clogged burner tube or orifice or the burner tube dislodged from the control valve.
cpaulsen
Oregon
Posted: 06/12/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Lights with a lighter or match ok. Sometimes it lights with the piezo ignitor and most often not. Tried getting the hood/cover off the burner but will not budge.
RobWNY
Jamestown, NY
Posted: 06/12/19 07:13am Link  |  Quote  |  Print  |  Notify Moderator
We have the exact same issue. On ours it's the front center burner. I'm going to take a look at it today and see if I can find the problem but I'm guessing it's the Igniter Electrode that's bad because like your issue, sometimes it works but often times it doesn't.
Update: I took the stove top off and used the spark igniter when I had a good look. It worked fine but the burner wouldn't light. So I took it apart, checked to make sure everything was clean and nothing was clogged up and put it back together. Now I can't get it to fail. [emoticon]
* This post was edited 06/12/19 10:22am by RobWNY *
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
fj12ryder
Platte City, MO
Posted: 06/12/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
It does sound like the ignitor is bad. Once you get the cover off, a very good addition to the stove is to add a battery powered ignitor in place of the piezo-electric noise maker. It's easy to do and if you get a setup with 4 ignitors you can add one to the pilot light in the oven.
D.E.Bishop
Eagle Rock, CA
Posted: 06/12/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
This site may be of help if you need igniter parts.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
 > Dometic stove
