RV.Net Open Roads Forum: Tech Issues: Fridge problem
 > Fridge problem
voodoo101
arizona
Posted: 06/11/19 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Freezer working but not cooling the refrigerator. 14? in the fully packed freezer that we started out with today. But the fridge isn't cooling down properly. In the fifties. This is a 19 year old unit and has always functioned well and we always pack the freezer pretty fall starting out for the summer. Something is not right. It's an older Dometic.
Dick_B
Palos Heights, IL USA
Posted: 06/11/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
If you are at a campground I'd call their recommended mobile RV Service guy.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
rk911
Wheaton IL
Posted: 06/11/19 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
smelling ammonia? betcha your cooling unit is kaput. if so ya got your money's worth...19-yrs old.
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
voodoo101
arizona
Posted: 06/11/19 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
No ammonia smell and freezer is cold
rk911
Wheaton IL
Posted: 06/11/19 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
freezer can be cold with a blown cooling unit. have a mobile tech come out and diagnose.
https://www.rvrepairclub.com/article/tips-rv-refrigerator-troubleshooting/
http://www.rvrefrigerator.net/Troubleshooting.htm
http://beamalarm.com/Documents/testing_a........bsorbsion_refrigerator_cooling_unit.html
DFord
Near St Louis, MO
Posted: 06/11/19 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Look around the back side for any signs of yellow residue that would be left behind if any of the ammonia solution leaked.
The refrigerator is cooled with spillover from the freezer. Until the freezer is down to temp, there won't be much spillover.
Don Ford
'09 HHR 2LT Towed - BX1648 Baseplate
Old-Biscuit
Verde Valley
Posted: 06/11/19 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Freezer will NOT cool if any yellow residue is evident.......
Same cooling unit so a leak affects BOTH freezer and food compartment
Freezer 14*F and PACKED FULL
Food compartment in the 50's
How long has fridge be ON ....and how long did you let it COOL Down before PACKING it with FOOD????
Why can't folks post MODEL of appliances???????
Boon Docker
Posted: 06/11/19 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
"freezer can be cold with a blown cooling unit." ????
That's what you would call Dometic Magic. [emoticon]
dougrainer
Carrolton, Texas
Posted: 06/12/19 05:33am Link  |  Quote  |  Print  |  Notify Moderator
It's true. A BAD cooling unit(not a leaker) will freeze the freezer compartment. The blockage is after the freezer coil. BUT, the temp is NOT at 0 to 10 degrees. It can be anywhere from 31 degrees down to 0 degrees. COMMON scam by people selling their RV. They show the buyer that the Freezer is very COLD, but it is not to spec and after they buy, they find out the refer cooling unit is bad and the CU needs replaced. Doug
wnjj
Cornelius, Oregon
Posted: 06/12/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the fridge door gaskets are actually sealing. I temp-fixed my sister’s by stuffing small scraps of paper towels in behind the gasket edge and it helped quite a bit with their warm fridge.
 > Fridge problem
