RV.Net Open Roads Forum: Travel Trailers: Terrible condensation/mold? What to use to prevent
 > Terrible condensation/mold? What to use to prevent
philh
Belleville MI
Posted: 06/12/19 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to the EPA nannies, there used to be a hanging product that stopped mold completely... but you can't get it anymore. I looked several years ago and there was nothing equivalent
jabres
Ohio
Posted: 06/12/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for all the helpful advice! Heavy scrubbing begins this weekend, and real good cleaning. Hoping for the best, makes me sick as we bought this trailer brand new to eliminate any problems.
thanks!
afidel
Cleveland
Posted: 06/13/19 09:45am Link  |  Quote  |  Print  |  Notify Moderator
DampRid or Humidri, two buckets of DampRid worked for us with 4 months in a damp cave, but if you're going 5-6 months the storeage place recommends the Humidri which is a bit more expensive but apparently does a better job (I believe it's a pail of the silica gel beads like what you get in many packages like shoes that a transported in shipping containers)
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
myredracer
Langley B.C.
Posted: 06/13/19 10:41am Link  |  Quote  |  Print  |  Notify Moderator
We're on the west coast of BC where it rains almost non-stop for 6 months over the winter. Have a cover on our TT in the off-season and crack a couple of roof vents and windows. Have never had mold. We use damp-rid, as do most. We have a hygrometer in the TT and humidity is a bit higher than I'd like but doing better than Damp-rid means a dehumidifier which uses power and needs emptying periodically (or draining directly outside).
The colder the outdoor temp. is, the less moisture the air will hold. Cracking a vent and/window shouldn't cause a problem. I would avoid ever heating the interior. Condensation of surfaces *might* occur, I think, if there is enough temp. change in the day like say when the sun comes out for a while then cools down quickly but if inside a barn might be unlikely. For those that camp in the winter, sealing up the interior to conserve heat is a bad idea.
The infamous "leaky condo crisis" of the 80s & 90s was caused by inadequate ventilation and leaking building envelopes (windows, siding, etc.). For many years, there were condos & other buildings all over draped in humongous tarps while they ripped off the exteriors, drywall & insulation down to bare structure and re-did it all. The building code in Canada was changed to require continuous ventilation, usually a bathroom fan hard-wired to stay on.
As mentioned, mold can be there and unseen. Take a food source like luan and just add water and voila... Some types are toxic. Can be difficult to eradicate sometimes, depending on type. Bleach will work in some cases, but not all. In the worst of cases, some homes can't be salvaged. If it's bad enough, the only way to eradicate it could involve pulling off the luan walls & ceilings.
I would get a hydrometer and see what the actual RH is. Maybe talk to a mold professional. Also check with your insurance co., if insured over the winter to see if covered.
* This post was edited 06/13/19 10:47am by myredracer *
I hate CAPTCHA. It just will not go away...
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2012 GMC Sierra 2500HD crew cab
