RV.Net Open Roads Forum: 2 - 6 Volt Batteries - Newb question
 > 2 - 6 Volt Batteries - Newb question
tonykennard
Sherwood Park, Alberta
Posted: 06/11/19 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
Good evening! First time poster, long time reader!
My 2 year old 2018 Funfinder 31BH is equipped with 2 - Interstate 6 Volt Deep Cycle Batteries (GC2-ECL-UTL). I noticed the other day that panel lights showed only the bottom light (basically dead batteries) when checking charge level on them even though they had been used very sparingly. I brought the batteries home, stuck them on the charger (BatteryTender Plus) for a charging cycle (about 1.5 days). when it was fully charged this morning I unhooked and let them sit for the rest of day. When I got home from work, I check resting voltage and Specific Gravity numbers and was shocked to find the following..
Battery F7
6.5 Volts
1 - 1.225
2 - 1.220
3 - 1.225
Battery H7
6.6 Volts
1 - 1.235
2 - 1.225
3 - 1.220
Am I correct in assuming these will require a equalization? I'm at a loss as to why the voltage readings are ok after the charge, but the specific gravity is so low. It was reading right at the line between white (ok) and red (discharged) on my hydrometer from Canadian Tire (not the greatest Hydrometer I don't think)
Any help would be greatly appreciated!!
pianotuna
Regina, SK, Canada
Posted: 06/11/19 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, and the batteries may be quite sulphated.
Regards, Don
3 tons
NV.
Posted: 06/11/19 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t see an obvious problem, but maybe this will help:
http://support.rollsbattery.com/support/solutions/articles/4347-measuring-specific-gravity
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 06/12/19 12:20am Link  |  Quote  |  Print  |  Notify Moderator
WOOL clothing is immune to battery acid.
Wear safety glasses
Make yourself comfortable and don't rush things.
I have equalized hundreds of batteries (may well be an understatement)
Some three cell GC batteries have taken in excess of 16 hours to equalize.
11 ELEVEN AMPS constant until voltage reaches 8 volts or 16 in aeries.
Sam Spade
North Central Florida
Posted: 06/12/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
I don't see a problem either, at least not one worth worrying about too much.
What exactly makes you think that the SG is low ??
The specific chemistry for that model battery might affect the SG readings some.
I would be more worried about checking your charging equipment.....and your usage routine....to see why they are going flat.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
pianotuna
Regina, SK, Canada
Posted: 06/12/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
This url may help:
http://www.batteriesnorthwest.com/batteryschool.cfm?TID=5#ANC5
time2roll
Posted: 06/12/19 09:32am Link  |  Quote  |  Print  |  Notify Moderator
What converter or charger normally charges these batteries?
Probably need to upgrade.
If parked in the sun consider 100 to 400+ watts solar.
675w Solar pictures back up
Sam Spade
Posted: 06/12/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
This url may help:
Good chart but incomplete.
Temperature has a substantial impact on specific gravity.
And voltage and SG usually track pretty closely.
Nominal voltage for a 6 volt battery is 6.3.
So his voltage and SG readings don't "track" with each other.....and one or the other is "off" or the chemistry of the battery means that it won't follow the chart for a "conventional lead acid" one.
rrupert
NW PA
Posted: 06/12/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
You may want to upgrade your converter to better handle charging the GC2 batteries. I started a thread on the subject and got some very good information in response:
Boondocker Converters vs. Progressive Dynamics Converters?
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
allen8106
Burrton. KS
Posted: 06/12/19 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Batteries need to be equalized at least monthly to stay healthy. If your converter can't do that then you need to find an alternative.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 36
