RV.Net Open Roads Forum: Class A Motorhomes: Fuel economy and additives
 > Fuel economy and additives
Tom in Tulsa
Tulsa OK
Posted: 06/12/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
So now i am trying to chase down a owners manual for a 2008 Triton V10. All Google does is route me to their highest paying advertisers or send me to some site that wants me to download their softwre on my PC....year. right...like i will do that.
I do need a PDF of a 2008 Triton engine if some some can send me a link without installing porn or some other cookie on my PC...LOL!
2008 Forest River Georgetown 357; F53 Triton V10 gas engine; Alison trans.
Onan 5000 generator
msturtz
Washington
Posted: 06/12/19 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
try duckduckgo.com they don't do that.
FMCA member
Tom in Tulsa
Tulsa OK
Posted: 06/12/19 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Jackpot!! https://owner.ford.com/tools/account/how-tos/owner-manuals.html
Thanks!
udidwht
Seattle
Posted: 06/13/19 04:07am Link  |  Quote  |  Print  |  Notify Moderator
For best MPG's find out where the low-high torque curve is on your engine and keep it in that range when driving on the highway. With my RV (94 Southwind Storm 28ft) that is roughly 58-62mph. Go north of 62 and the MPG's drop fast.
My last track from Renton, Wa. to Medford, Or. I netted 10.4mpg. Coming back same stretch it was 8.4mpg (headwind). No towing.
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 58,301 miles and counting....(as of 06/08/19)
VIN# 1GBJP37N4R3314754
time2roll
Posted: 06/13/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
I would do nothing. Just drive and enjoy the trip. All sounds like you are running good... so don't fix what is not broken.
675w Solar pictures back up
Dale.Traveling
Newport News, VA
Posted: 06/13/19 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Tom in Tulsa wrote:
,,, Questions: 1. Do fuel additives work and which ones do and don't. Fillups are around 50 gallons on a 75 gal tank.
2. Is going to 100% gas (no ethanol) cost effective?.
3. My Class A is 2008 (11 years old) with 53,000 miles. Is it time for a tune up and what gets tuned up? Spark plugs, injectors, wires?
I am not a mechanic and am only guessing.
What works and what doesn't? ,,,
1. For the purposes of increase fuel economy fuel additives do not work. If one did every gas RV owner would be buying it in by the pallet load.
2. Cost effective? No. 100% gasoline fuel does have a higher percentage of BTUs and may increase mileage slightly but it is unlikely you will see enough of an increase to make up for the higher cost of the fuel.
3. The plugs are good for 100,000 miles. Coil packs (replaced the plug wires) area replace on failure item. You could try an injector or "top end" cleaning service but if the coach is performing adequately at speed then do nothing.
What works to help with mileage?. Pretty much nothing you can buy. Best practices will help the most. Stay on top of routine maintenance and inspections. Keep your load and associated coach weight as low as possible. Watch your speed and go easy on acceleration from a stop.
Consider a Scan Gauge which you can use to monitor instant and average fuel usage to help lighten your right foot. When you see an instantaneous usage of 1.2 MPG it has a way of getting you to back off the throttle.
2006 Hurricane 31D built on a 2006 Ford F53
1320Fastback
Vista, Ca
Posted: 06/13/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
My understanding is that fuel additives only work by making your wallet lighter and a lighter vehicle is easier to move down the road.
Also your best miles per gallon should be in the highest gear possible at peak torque.
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
Bill.Satellite
Full-timer
Posted: 06/13/19 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Tom in Tulsa wrote:
I drive a Forest River Georgetown w 4 slides an a V10 Triton gs engine. Typically i drive 62-65 mph on the hwy.
I will be doing a gas log of my fuel economy, but I think it is 7.5 mpg fully loaded. I do use regular unleaded gas ($2.25 per gal in Tulsa area now).
The Bluegrass Boy.
1) NO!
2) NO!
3) What do the manufacturer specifications say?
Don't waste money trying to make a super heavy square box with wheels preform like a sleek, lightweight, automobile!
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
DrewE
Vermont
Posted: 06/13/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Not really; peak torque is probably where the engine is most efficient, but that does not mean it's the most efficient speed for the vehicle as a whole. Usually the most efficient speed would be about as slow as you can go while still staying in the top gear and not lugging the engine too much.
Air resistance, a major contributor to the frictional losses of a vehicle (and especially so for one as aerodynamic as a barn or brick), increases with something between the cube and the fourth power of speed. A relatively small increase in speed requires considerably more power, and hence a greater rate of fuel consumption.
I haven't done much study with my motorhome, but I can definitely say that with my car 45 mph or so is noticeably more fuel efficient than 65 mph, while the peak torque in the top gear would be at some speed above 75+ mph. (I don't know precisely what its torque curve looks like.)
1320Fastback
Vista, Ca
Posted: 06/13/19 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe I'd read it's for a vehicles designed to pull or diesels then. My peak torque is at 1,600RPM and in 5th gear that equals 57 mph with 3:54 gears. Seems to the be sweet spot aerodynamically and coincides with my engines efficiency.
