RV.Net Open Roads Forum: Travel Trailers: Setting up wdh hitch
 > Setting up wdh hitch
jy
south east mich.
Posted: 06/12/19 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Recently bought a 28 foot travel trailer from a private person.It came with the hitch and bars and he said it was all set up for my truck.(f150) I towed it about 50 miles home and definately have a sway issue.Watched a few u tube videos on setting up the hitch but they seem to disagree. Any suggestions on the best resource for instructions on setting up the hitch?
2016 wildwood bunkhouse,2018 f150 5.0.Camping with the grandkids now.
Iraqvet05
Greenwood, MO
Posted: 06/12/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Who makes the hitch?
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
jy
south east mich.
Posted: 06/12/19 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Trailer is back in the barn,I,ll have to get back to you on the brand of the hitch.Its the kind where the bars don,t have chains. they slide on top of metal L brackets which are attached to the trailer tounge.
Iraqvet05
Greenwood, MO
Posted: 06/12/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
That maybe a Progressive E2 or Equilizer 4 point hitch.
drsteve
Michigan
Posted: 06/12/19 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Husky Centerline TS is like that too. I have one, works great.
OP, your best bet is go to the manufacturer's website and download the instruction manual. Hitch setup is pretty straightforward.
1991 Palomino Filly PUP
APT
SE Michigan
Posted: 06/12/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Check out this thread.
2017 Subaru Outback 3.6R
ppine
Northern Nevada
Posted: 06/12/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Have someone check you setup. If you still have sway, add a sway control bar. It is relatively easy to install and costs around $60.
jy
south east mich.
Posted: 06/12/19 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Ok so I found a sticker on the bar that says e2. so I guess its a progressive e2 set up.
Iraqvet05
Greenwood, MO
Posted: 06/13/19 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the L brackets and the bottom of the friction bars are clean and dry. Next, make sure the rear tires of the tow vehicle are inflated to the max. If the bars are fairly easy to put on, the hitch probably isn’t set correctly. Go over the manual, take measurements of the unloaded and loaded fender heights and go from there. Also don’t forget to put some weight on the tongue when you load up the camper. Too light of a tongue load will cause sway. I had the E2 for 5 years pulling a 6k lb Jayco. The E2 isn’t a bad hitch but it has its limits.
