RV.Net Open Roads Forum: Tech Issues: AGM Battery Maintainer
 > AGM Battery Maintainer
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 06/12/19 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I am giving the BORG a rest. Things like fans wear-out and after 24/7 for ten years and after not having a single power failure here it's time for wisdom to rule.
The maintainers have matured over the last 10-years. I would like to find one with perhaps a 1.0 - 2.0 amp capability as I am still using an active battery backup for my CPAP and .8 amp bedside reading light. The maintainer will be placed atop the battery -- should make the temp compensation accurate.
I don't want to stray too far from Lifeline specs for float.
Thank you in advance!
Sam Spade
North Central Florida
Posted: 06/12/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Contact Lifeline for a recommendation ??
And while you are talking to them, ask what the disadvantage, if any, would be to using an "off the shelf" battery tender without a "special" setting for AGM.
You might be surprised at the answer.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
