RV.Net Open Roads Forum: Fifth-Wheels: not enough hitch weight capability
 > not enough hitch weight capability
Road Phantom
pa
Posted: 06/12/19 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought a 2018 ram 2500 diesel 4x4 crew cab with a 2400lb rating for carrying capacity and 17,000 tow limit. My hitch weight is 1950lbs. By the time I add up fuel, my wife, (she's only 140lbs) the hitch itself, there's nothing left for the front storage of the fifth wheel. Air bags won't increase my GVWR.
I plan to move the portable gen and tools inside over the trailer axle and anything else that's heavy. I've seen a lot of rigs in the campground with similar setups and many running much heavier loads than my 9000lb empty trailer. Any solutions besides those mentioned would be appreciated short of asking me to buy a one ton for a few hundred pounds overweight on the hitch. Thanks for your constructive help.
Old-Biscuit
Verde Valley
Posted: 06/12/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Rear axle/Tires carry the Wet Pin weight
Don't exceed those ratings.
Old debate over GVWR/Payload
Mfg. sets the GVWR and Payload is based on that number
Many States allow you to register the truck at a higher GVW just pay the higher fees....so even many States do not recognize the MFGs GVWR
MANY will scream/holler but one just has to think for themselves and make an informed decision on what is OK for them
Hang on....it's going to get bumpy [emoticon]
Hammerboy
Zeeland, MI
Posted: 06/12/19 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
My truck has about 2450# payload and when I went to the scales with loaded 5ver in tow and wife in truck I was #280 over the weight limit of the truck but 660# under my rear axle rating. I'm happy as long as I'm not over my axle or tire ratings.
Dan
2013 Chevy crew 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
Sandia Man
Rio Rancho, NM
Posted: 06/12/19 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Like you stated there is not much else you can do that will increase your payload, you have plenty of truck that a few hundred pounds more or less should not be a deal killer. Take her out for a run, I think you will find the towing experience acceptable. My old Chevy HD gasser has nearly 1K# more payload but it sure would not be able to haul anything near a 17K# 5er.
Arcamper
Fayetteville, AR
Posted: 06/12/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I saw something Monday I thought was odd but I guess legal as stated above. A road that goes across interstate 49 I cross everyday was under construction and there was a GMC 2500 pickup sitting there from Manhattan Road & Bridge. Under their logo was the following "GVW 18,000". Could not see what state plate it had and I did not have time to get a pic but I know what I saw. Must be one bad a$$ 2500.
2016 Montana 3100RL Legacy(LT's,Joy Rider 2's,disc brakes)
2014 Ram 3500 DRW Laramie Cummins/Aisin 14,000 GVWR
2014 Ford Expedition Limited, HD tow pkg
2016 Honda Civic EX-T
1999 Stingray 240LS
1994 Chevy 1500 5.7 PU
2018 John Deere 1025R
B&W RVK3600 Hitch
IdaD
Idaho
Posted: 06/12/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
GVWR on 3/4 tons is class maxed at 10k lbs and is meaningless on a diesel truck. You have 6500 lbs or RAWR and with bags I wouldn't hesitate to run that up to the 7000 lb rating on the same year 3500. You've got plenty of truck to load up your trailer and not worry about it.
2015 Cummins Ram 4wd CC/SB
laknox
Arizona
Posted: 06/12/19 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
First off, weigh your truck and trailer at a proper CAT scale with your current setup, to get all axle weights. Then, check those #s with your placard and see how close you are to your RAWR and tire ratings. If you're over on your GVW, but under on your axle and tires, tow it and have fun. You =can= physically increase your GVW some by using an add-a-leaf type upgrade. Not sure your state registers by weight, so you could, technically, have a 1t truck with 2500 badges on it. Up to you whether you "declare" it. [emoticon]
FWIW, my '02 D'max is supposed to have 245 tires, which puts my tire rating =below= my axle. It had 265s on it when I got it, and that's what I've put on since then. Now, I'm several hundred =over= my axle.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
camp-n-family
London, Ontario
Posted: 06/12/19 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Keep it under the axle and tire ratings and you’ll be more than fine.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
Walaby
Georgia
Posted: 06/12/19 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Focus on RAWR. Make sure your tires are equal to or greater than RAWR. Weigh with 5er hooked up, loaded for camping. As long as you are below RAWR you will be fine
Some will eventually chime in that your truck will disintegrate if you exceed payload by 10 lbs and that you will be sued for all you own if in an accident. You can follow their advice or make an informed, rationale decision. Your choice
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
JIMNLIN
Oklahoma
Posted: 06/12/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Good advice so far Adrain...just to expand a bit. Your 2500 Ram has the same AAM 11.5" rear axle used in the 3500 SRW trucks. For a while it was used in the 3500 DRW as a 9375 rawr.
Get some scaled axle weights.
