RV.Net Open Roads Forum: Travel Trailers: Replacement mattress
 > Replacement mattress
GrandpaKip
Flat Rock
Posted: 06/13/19 07:48am Link  |  Quote  |  Print  |  Notify Moderator
For around $500, you can get a decent mattress and you won’t hit the plywood base.
If you do the work, the bathroom could be less than $2k.
Seems like you don’t really want to buy a new one, so just fix the one you have.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
DownTheAvenue
Sunny South
Posted: 06/14/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Huntindog wrote:
DownTheAvenue wrote:
Just go to a mattress store and buy a top quality house type mattress.
This is often not an option. RVs are known for having special, non standard sizes.
Actually this is a very viable option regardless of the mattress size. Many mattress stores can order a specially sized mattress made to order! Check out Original Mattress Factory stores as just one example.
myredracer
Langley B.C.
Posted: 06/14/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Memory foam mattresses are easy to trim. We bought a nice new 8" memory foam mattress while out on a camping trip 'cause it happened to be on sale at a blow-out price. Just used a bread knife (sharp) to cut it. Not a 100% perfect clean cut but you'll never see it again with sheets on it. This mattress has given us the best sleeps compared to our fancy expensive memory foam mattress at home. OEM standard mattresses are like medieval torture devices... [emoticon]
Sometimes you may need to reinforce the plywood or OSB the mattress lays on. They can be poorly supported underneath. Our OSB is sagging like a bowl and I've gotta get in there and install some angle iron. Solid 2x3 can work on the edge (screwed from above) but may interfere with storage in a pass-through. Or install it on the flat and maybe use another piece or two if needed.
I hate CAPTCHA. It just will not go away...
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2012 GMC Sierra 2500HD crew cab
