RV.Net Open Roads Forum: Class A Motorhomes: Triple digit heat! Generator won't run
 > Triple digit heat! Generator won't run
viajante
Plumas Lake, CA, (near Yuba City) USA
Posted: 06/12/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
We have a real issue! Triple digits, ready to leave for our trip in one day and the generator won't run the a/c.
We had unplugged shore power to cool the 2008 Itasca down for some pre-trip honeydo's, Went outside to see if it was cool enough and someone had plugged the #@%$ thing into shore power with the generator running! We've had some issues with things being touched in the past - but nothing this bad. Now, I've turned everything off and left the mh sit for 20 minutes. Returned and generator turned over and all seemed to be working till I added the a/c. It would not run it!
Anyone have any ideas what may have occurred, or better yet what do I need to do to fix this???
Dave & Brenda
Shadow (Sheltie), and Zoe (Shih Tzu)Faithful Companions
2008 Itasca Sunrise 35L
akrv
Green Valley , AZ
Posted: 06/12/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Check circuit breaker in the panel.
2005 Coachmen Concord 275DS
2004 Malibu Maxx LT
CA Traveler
The Western States
Posted: 06/12/19 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Reset and set the CBs. Check the voltage at the ATS to determine if you have gen power on the input and output.
2014 Grand Cherokee Overland
Bob
Robh242
East Coast
Didn’t see that the gen was running.
* This post was edited 06/12/19 08:09pm by Robh242 *
viajante
Posted: 06/12/19 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what that is?
viajante
Not sure where to find the generator reset?
DownTheAvenue
Sunny South
Posted: 06/12/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off very circuit breaker and turn back on. If everything works on the generator except the A/C, then I would suspect the circuit breaker fr the A/C has tripped. Also, double check the operation of the A/C on shore power- be sure the A/C itself is not the problem.
Robh242
East Coast
Posted: 06/12/19 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
You need to review and learn your Circuit Breaker box. Hence, CBs. Electrical panel for coach.
viajante
Posted: 06/12/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I checked all cb panels, but could not find one for the generator.z
wolfe10
Posted: 06/12/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
First, if you have an ATS (Automatic Transfer Switch) which I suspect you do have, no damage was done by plugging in assuming the ATS was functional.It's job is to only allow ONE source of 120 VAC to the main breaker panel-- either shore or generator.
The generator has two breakers on the generator itself. Turn them off an back ON.
If generator is running (i.e. not out of fuel, etc) exactly what 120 VAC things are working and not working?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
