RV.Net Open Roads Forum: Tow Vehicles: Why 4.1 axle?
Search only in Tow Vehicles
 > Why 4.1 axle?
Page of 10
time2roll
Posted: 06/18/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
With more overdrive that is all the MORE reason to have 4.10
Gear 6 and 9 is virtually the same. So the gear 10 allows for lower rpm with the 4.10 ratio.
3.xx is grocery gears. 4.xx is towing gears.
The only reason I say 4.10 is that most would call 4.56 or 4.88 absolute bonkers. Anything 4.xx is reasonable with those overdrive ratios.
If you want to run 3.20 gears... that is fine with me also.
675w Solar pictures back up
mich800
Pontiac, MI
Posted: 06/18/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Than you defeat the purpose of the highway gearing unloaded. 1-5 are all deeper so you can get the same performance towing with a higher rear gear and extra economy when not. Remember, the reason for these transmissions is for cafe.
blt2ski
Kirkland, Wa
Posted: 06/18/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
If said rig is a high enough gvwr to not meet cafe studs, all you drive is 60-65 mph, why not axial yourself to high gear to towing at max weight you will be. Allow to USD a deep low, assuming you pull grades steeper than 12% as current min tow rating specs are,and have a.better tow rig for MY application, not some person that thinks they know what I need. I rarely am in an area I can drive over 60 mph. And with in my state, if over 10,000 gvwr, max speed is 60 mph. Don't see a reason for a great that will allow me to cruise at 80 mph.
Marty
Check RV.Net Blogs at: blog.rv.net
mich800
Pontiac, MI
Posted: 06/18/19 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Marty
Half tons are included. And cafe are not measured towing trailers. I think we are staring to lose sight of the forest. I would love for the manufactures to build one off vehicles that met the spec for every individual driver. But that is not possible so the compromise of meeting government mandates and consumer wants occurs.
time2roll
Posted: 06/18/19 10:42am Link  |  Quote  |  Print  |  Notify Moderator
How hard is that to have optional gear ratios? Customer pays the extra cost.
Now if they would option a TrueTrac differential front and rear we would really be getting somewhere [emoticon]
BenK
SF BayArea
Posted: 06/18/19 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Gleason's are nice...wish the budget would allow...but...there are higher items on that list. A Detroit will suffice for now
Close ratio trannies were/are available, but in most cases...an adaptor & and "stuff" has always been nevessary. Have one built and ready for my 2 seater...5 speed w no OD manual to replace the stock 4 speed and no adapter needed
Marty is right, the 4L80E has a too low numeric (to high 1st gearing to tow heavy where there are steep inclines) and one reason ordered my K3500 with 4.1's
Won't spend the kinds of money on these new trucks and better spent, IMHO, on rebuilding to "my" specifications....turning my 4 speed with a single OD, into an 8 speed with double OD
1st will be lower than the 4L60E and with an approx 2.6 OD...haven't decided on the tire revs per mile yet. Probably sticking with what is on there...or LT255/85R16'
Personal choice...if you know HOW2 spec it out...or stuck with whatever the OEM of your choice provides
Too many only look at a component of the whole system...
Also...lost to them is the understanding of how gearboxes multiply torque
* This post was edited 06/18/19 12:46pm by BenK *
-Ben Picture of my rig
time2roll
Posted: 06/18/19 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
The thread is about "Why 4.1 axle?"
Not about efficiency, CAFE, running quietly at low rpm, defeating the OEM set up, or justifying 3.20 ratio etc.
mich800
Pontiac, MI
Posted: 06/18/19 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Fair enough. Why are we talking about the Ford 10 speed?
jaycocamprs
Ringgold Georgia
Posted: 06/18/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
But the CAFE test doesn't really reflect the real world.
I did not by my truck to run high speed empty. I bought it to tow. If you run 60+ most of the time the high speed gear is fine. If however you rarely drive over 45 mph then the low gear will get you better city mileage. And I've yet to see more than 1 reverse gear. I've seen a lot of people that did not have a low enough reverse gearing. But I don't live in flat country either.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
valhalla360
No paticular place.
Posted: 06/19/19 06:16am Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
Are we discussing why somebody would pick a given rear ratio, in this case 4.1 to 1, right? I don't have much experience with light duty stuff like what RVs use. What I have done is decide how much weight I need to move to make it pay, then try put the gears and axles under the frame to get the job done. If you got 50,000 lbs on your back, and the customer says "Take it across that bean field, dump at the tree line" You are going to grab a double handful of seat with both hands on the wheel. If you thought the 4.1s could save you fuel over the 4.44s you start counting how many gallons you could buy for the cost of the power divider. That old Pete with the 1693 Cat, 2 stick 5X4, and 5.56 was the best I ever had for that kind of work, but hard to feed on a lot of other jobs...
Again, if you need a higher tow rating yes a higher numerical rear end can help...I said that in my first post.
But most of the comments have been related to fuel efficiency and towing comfort (ie: it doesn't feel like the engine is struggling) but also presumes you are aren't exceeding the weight ratings for the truck.
If you aren't exceeding the weight ratings, a different rear end isn't going to have much of any impact with new trucks with 8/10 speed transmissions.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Page of 10
 > Why 4.1 axle?
